Window trim rattle/vibration
Donmatteo
Santa Clarita / Coronado
I added the felt to the inside of the rubber weatherstrip that the window connects with. It was a piece of felt about 8 inch long that rattle/vibration is gone. Going to have the dealer look at it at the next oil change but that was the fix for mine.
Jack55
United States
Mind sharing a picture Don? the buzz\rattle on the driver side drives me crazy
Donmatteo
Sure. Here you go. it's a little hard to see.
I bought this and cut it in to a strip about 9 in long (that's what she said) and about 1/8 wide.
when the window is up, that little bit of felt pushes the seal out and fixes it.
As an Amazon Associate we earn from qualifying purchases.
Butterz
San Diego
I had similar rattle noises after some extensive warranty work. Going 70+ the passenger side and the driver side doors would have the rattling and much worse with the sunroof open.
My issues were the door seals weren’t securely clamped down. Not sure if they replaced them or just reseated them, but have had no noises since.
Finlay150
Marietta, GA
Add my 24 to the B pillar rattle. Just a bit of pressure on the glass in the lower back corner and it goes away. I have just over 7k miles on it and it's getting worse. Right now if just roll the window up and down a couple inches it goes away for a bit.
JDMCTR00
Los Angeles,CA
View attachment 458652View attachment 458653
Mine just started (4500 miles on my 2023) to rattle at this location. With a little pressure on the glass or the seal from the inside stops the rattle. I'm going to try that felt from amazon.
Dev
PA
Did ya find a fix?
Finlay150
Marietta, GA
Dev
PA
JDMCTR00
Los Angeles,CA
I have the rattle a lot more when I fully open the sunroof and leave the windows up. When it rattles I lightly push on the glass and it stops. Also, if I lightly push/hold the trim from the inside it stops. I haven't had the chance to add the felt tape yet.
