Auto Up/Down Windows stopped working...
gdflynn1
New Jersey
Sorry in advance if there's an answer, I searched and found no instances of this problem occurring.
Anyone have this happen to them? All other windows auto-up/down work, as expected.
Passenger window, no dice. It goes up and down, but wont auto-up or down.
A small inconvenience - but curious if this will become a nightmare when I likely have to go to dealer for warranty coverage to fix
FordTechOne
Detroit
From the Owners Manual:
Resetting One-Touch Close
Carry out all steps within 30 seconds of starting the sequence.
1. Close the window.
2. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a few seconds.
3. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a few seconds.
4. Press and hold the window control switch until the window is fully open. Keep the window control switch pressed for a few seconds.
5. Lift and hold the window control switch until the window is fully closed. Keep the window control switch held for a few seconds.
Note: Repeat the procedure if the window does not close when you use one-touch.
gdflynn1
gdflynn1
New Jersey
You the man @FordTechOne - going to give that a try. I feel like an idiot now not looking at owners manual - would have never assumed an answer to be there. Duh
cobering55
Minnesota
My window when I open it shakes bc it doesn’t go down fast enough like when u open and close the door it moves an inch but on the drivers door it seems to not be fast enough and makes the window shake when opening
swoop1156
USA
All other windows, meaning the only other window? My truck only has two that are auto up/down... I wish the rear did it as well. Please tell me I'm an idiot and there's a way to enable this. Back in the day I got modules from a junkyard Taurus and spliced them into my Rangers, but it's a different game, now.
directed 535t
New England
this only fixes it temporarily issue resumes in a few days
