How to turn off adaptive cruise control
FuryRaptor11
El Paso, Texas
I'm having issues with my collision warning sensor and for some reason my adaptive cruise control isn't working ..do you guys know how to turn off adaptive cruise control and use regular Cruise control?
Thanks
Small Town Raptor
Petawawa, Ontario, Canada
Thanks
1). What issues are you having? Blocked sensor? Malfunction?
2). Not for some reason....if you have a collision sensor problem, your ACC will no longer work. They use the same sensor.
3). Under the advanced settings on your centre screen menu. However, if you have something more terminal than just a blocked sensor, and you get the sensor malfunction warning after you start the truck, you CANNOT turn off the acc and traditional cruise is no longer avail either.
NHDude4
Southwest, NH
Sounds like your radar is malfunctioning. I'm pretty sure the correct solution is to take it in to be fixed under warranty. I wouldn't just disable the feature and call it a day.
Larry Jeffords
Queensbury, NY
Correct me if I'm wrong but isn't the intent of these forums to share information and ideas? I belong to a Harley forum and a Jeep forum too and every once in a while I will post a question to see if anyone else has experienced the same or similar issue as I am and perhaps find a quick solution. In the case of my Raptor, it saves me from thumbing through the 628 pages of the Owner's Manual.
Unfortunately, there always seems to a few that find it necessary to post negative, sarcastic or otherwise useless responses . I'm sure the moderators have better things to do but it's too bad they can't delete the negative posts and block the senders.
