Custom Heated Carbon Fiber Steering Wheel Gen1/Gen2 - Group Buy
Status
Not open for further replies.
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
So you can do colors like Ruby Red? Can you customized the width of the top center stripe?
As for returning your current steering wheel, does the condition of that wheel matter? And out of curiosity for those that don't know (like me), what's the reason for requiring the old wheel?
Yes, you can choose the color of the top stripe as well as the width. You can choose the stitching color, colored carbon paddles, etc.
These steering wheels are built from the OEM steering wheels. So your core will actually be modified into what you see here. It needs to be in pretty good shape but a few scratches and a few dings wont make any difference.
melvimbe
I asked because the previous owner on mine used a brace attached to the wheel for steering. The damage is only on the leather itself as far as I can tell, core seems intact.
Blake Jones
How does the heat work with a gen 1? Inhave sync 3 installed but dont see a button for it. Also is there a way to get the adaptive cruise to work?
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
For a gen1, you'd need to install a switch or connect it to an existing switch to control it.
rkneeshaw
Northern Michigan
It would be sick if enabling the heated stearing wheel in Sync 3 retrofit worked. Any idea if the heated steering wheel responds to a CAN bus signal for enabling/disabling the heating element?
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
Possible, but untested.
Joe12345
PA
Given my experience with both Ford dealers (16 Taurus SHO) and fiat Chrysler (18 JL Wrangler) this will be a hassle, as all dealers will refuse to unlock the capability even though they have the ability, because it’s not a sales code tied to the VIN. Your only hope would be to convince an aftermarket company who deals in these things, such as Tazer and OBD Genie, to see if they can engineer that into a software solution for you. They’re both usually willing, but it’s usually a year from the ask to the result, so you’ll have to be patient.
richmeyer
Wisconsin
mmmmmm, carbon.....
Anyone that jumps on this and needs to get rid of their stock gen 2 wheel, holler at me.
Status
