BRAPPPP
I have read tons of threads on springs and bump stop systems. I know I want to go with RPG Stage 3 for my setup, but I am still unsure on the spring setup. I really would like the rear lower because I do like the nose high look and I saw a raptor with his oem block removed on the road and liked the way it looked planted to the ground. I definitely want to go with some aftermarket springs (+1 or +2) either National or Deaver. I know that RPG only sells +2 nationals now because the +1 limits up travels and you ride on the bump stops more. Are the 1+ truly going to limit the up travel of the truck or are the shocks the real limiter? If anyone has pics of +1s on Top or Middle perch that would be awesome if you could post them. Right now I'm On top perch and I'm assuming the 2+ would keep it how it is. And if I went middle perch with +1 it would be similar in back to front ratio as I have now. Thanks!
