Another Reason Why..
jeff
Riverside/Irvine
Around December i had ford install a leveling kit on my Raptor(what they recommend to not void warranty)
After going on the Desert Heat Run and talking with Gordon i decided to remove the leveling kit and do the middle perch this week especially after reading BigJ's post. I Had all the markings where the Upper control arm were hitting the coils and could see all the stress on my CV's. And it was noticeable the truck was not handling to its full potential.
A local shop quoted me 220 to remove the kit and install perch. when the took the truck apart this is what they found :disgust: .....
The welding broke all the way around
this was the other side not broken yet but definently was close
Please , anyone thinking about a leveling kit save your money and frustration
-Jeffrey
(p.s i apologize for my grammar or poor write up skills )
NickPic83
Rockland County NY
Any1 tried daystar 2" ? They seem much stronger than those in pics...
i think the daystars are what bigj used. lots of worn parts on his truck when he pulled it off. do NOT do a level kit. no need with the ability to do perch mod. they made the truck for mid perch, only reason they dropped it to bottom was for DOT
whtrapta
Ostrich Wrangler
Bolivar/Springfield, MO
Stay away from the kits! they allow the suspension to drop further than it should causing it to hit and stress the CVs. Plus mid perch is how you get the suspension to act how it should. Bottom is too soft and spongy.
BigScott
Banned
goin ******* on ur ass
Desert Heat was a good run. A mixture of fast, slow rocky, and some fast whoops. I'm not suprised those welds broke. At least you will be good to go for next run.
After a second look, you are lucky there was enough preload in springs and or not enough droop to let that whole assembly lift apart and then you could have been REALLY F€£&ED
jeff
jeff
Riverside/Irvine
yea i do not even want to even begin to think about that.
I just wish ford knew more about there product before putting something like this together, i'm pretty sure i paid more then double what my perch mod cost for ford to install a leveling kit. oh well live and learn
Yukon Joe
Trafford, PA
So, if Ford installed under warranty , and said it would not void warranty, then why not have them remove it and replace damaged parts??????
Joe
96,424
60,353
indiasurfex
