Rear Facing Ambers...Thanks WSI
Big Blue
Administrator
Staff member
Admin
USA
Final install done for Havoc...
Rear facing Whelen Vertex ambers. For such a tiny light, they put out some serious lumens!!! Looking forward to seeing them tonight in the dark.
I did not want wires running down both sides of the light rack....so radio antenna and both lights are routed through the 3rd brake light....:patriot:
Rookie
Fort Wayne, IN
You have any night shots? Also, the vertex is a common emergency vehicle light. Did you wire it to stay on constant or did you install a switch on the Scan wire so that you could alternate patterns if you wanted?
I was looking into getting some flush mount Rigids for the rear in amber for visibility purposes but this is a better solution IMO and cheaper. Plus if you install two on the rear you can utilize them in a flash sequence if you're ever on the side of the road changing a tire or something (check your state and local laws before doing this).
Yukon Joe
Trafford, PA
I think Mike has these wired as a constant. As do I.
For night shots, they are bright. They will light up the bed of the truck which is nice.
Yukon Joe
www.RUNRAPTORRUN.com
Big Blue
Big Blue
Administrator
Staff member
Admin
USA
Joe is correct.
Wired mine for constant on. I run them during crappy weather on road, so I did not want to freak people out with the flashing, but you can choose like 30 variations.
Here is a pic at dusk, very bright and as Joe said, lights up the entire bed of the truck too...
Rookie
Fort Wayne, IN
Thanks for the responses. This is a great alternative. I'll def be ordering a set before the Snoball. Won't benefit me much but they help those out behind you.
