Rear Facing Ambers...Thanks WSI
Big Blue
Big Blue
Administrator
Staff member
Admin
USA
Here's what my intentions are... After making the video I did learn that I will be able to get rid of the sync switch so all I will have is the main power switch (AUX 4) and two pattern switches. I ordered a momentary on/off/on switch so I can utilize one switch for both pattern wires.
Id like to rewire mine in a way so I can have constant on with a swtich and then are still able to have them flash with a second switch.
Rookie
Fort Wayne, IN
The way these are setup it wouldn't be hard. I'm probably going to mount the pattern switch in the rear of the cab on the drivers side. Rear facing it's hard to cycle patterns when you can't see them. This way I could stand outside and watch them while I reach inside and cycle to the pattern I want real quick.
Sitdown
Suburbia, IL
When I plow into you due to the seizure you gave me from those flashing, i'll let you determine if their counterproductive :banana-mario:
Theproperedneck
CT/NH
Whelen makes a flasher that can do this. The flasher normally blinks but when you hit an over ride button that turns it to steady. Hit up Jimmy at WSI if you want one I think its less than 100 bucks.
Rookie
Fort Wayne, IN
I think that would require a different light? The way these are wired I can't see them just switching directly between steady and alternating flash. The flasher module is in the wiring.
Wilson
South Dakota
how about if you wire them to your tail light's? with the switch for on if you want them on constant.
Rookie
Fort Wayne, IN
That would work if you want them constantly on but these things are bright enough I wouldn't want to run them non stop.
Members online
96,206
60,054
stephan1075
