Mil T
The description for this page, The Raptor Tech Forum, says its for the tough issues with our trucks. Well, After 1.5 months of chasing a gremlin and now a noise in my truck I hope I can maybe get some ideas for the next course of action.
At the beginning of October I started having issues with my fault code lights and navigation screen shutting down on me at various intervals. I scanned the truck and no fault codes came up. But the hill decent light, tpms, eps, emerg. brake light etc. would start flashing and chiming and the nav screen along with blinker indicator lights etc. would all shut down. Off road button does not work when this happens along with most everything that is associated with the dash.
What I've done so far. I've checked all the ABS sensors and all are ok, Pulled the steering wheel to see if there were any loose wires etc. I posted a tech article, on the forum here, on how to remove steering wheel from that experience. I've pulled the connectors for the abs sensors and cleaned the connectors. I've checked the ABS module for any damage etc. (someone had said that the module heats up and can throw the faults and cause the same problem that I have). It does it's weird thing even if it's cold right out of the garage. I've checked for loose or disconnected grounds on the frame etc. I replaced the third brake light as there was some correlation with that becuase of the oem light leaking and buring the 3 leds in the light out for some on the forums.
On my noise problem I pulled the front wheels, brakes, and hub to check for bad bearings or anything that could cause a noise like this at the same time pulling the abs sensors to check for cracks or anything out of the ordinary. I've pulled the front diff cover to check for anything that looks abnormal. I"ve narrowed the noise down to what I think, (with several other people listening) to a catalytic convertor that is possibly going bad. The symptoms are a grinding or tinny rattle when I am accelerating above 20 mph and on up. it has progressivly gotten worse over the past week. The noise is very prevalent. The best way to describe it although I know this is not it, is a rock or something that has gotten between the brake dust cover and the rotor. The noise is not RPM or Speed oriented meaning it does not increase or decrease in severity when speeding up or slowing down.
On my scan tool I do not get any fault codes but I don't think that my tool is all that technical and that the dealers may have better ability to read either hard or soft codes.
My truck is out of warranty with 38K miles so I'm on my own dime. The Cats are probably still under emmissions warranty if that is what the noise is.
Anyway. I'm looking for real world feedback like someone that has had this type of issue and found the solution or a ford tech or those that deal with this type of thing. Conner at Outlaw and the owner of ADD both gave me some good advise but it did not seem to help the electronics issues.
Thanks in advance for any help you might be able to throw my way.
Mil T
Mil T
