Stock lug nut - chrome cap issue
  • Start date
During TRR when we changed a couple tires, my 21mm would not fit. Because out on the trail, we had no choice but to pound on the socket to change the tire. We even tried the stock lug wrench, same issue. When we got back to camp we notice it seemed like the 21mm socket wouldn't fit any of them. It was like the chrome cap swelled and we ended up tearing some up. I don't know if this was all the water/mud and heat or what.
Is this a common issue and has others seen this with theirs too?
Yukon Joe
Trafford, PA
Rick I've had similar issues as well. I've had to replace quite a few of them because of it. I notice that some of the dealers and shops use a socket that may be worn or a 13/16".
I think it causes the chrome cap to become a bit rounded and won't let the tight fit of a new 21mm socket to fit.
I had one tire shop ruin a set on a wheel I had them fix a tire on. I called them out on it the next day after I couldn't get my socket on it that night. The guy came out with a 21mm socket and said his wouldn't fit either. Well no shit. That what I just told him. Then I asked him how he got the wheel off the previous day. He didn't have an answer. Ass!
Carry a few extra with you incase some get messed up and you need to do a trail change. At least you'll be able to put a good one back on.
Yukon Joe
Got a part number for these? SE beadlock wheels if it matters.
Or does Gorilla make some same size black ones that are better quality without a cap that work with these wheels?
t_j
Chicago, IL
I have replaced a few and at over 5 bucks a pop they are not cheep. I have resorted to a 22mm on ones that have been trashed. None of my local Paros stores carry a basic 14mm x 2.0 lug.
gDMJoe
Timbuk3, MI
RDFTS ... Or does Gorilla make some same size black ones that are better quality without a cap that work with these wheels?
Yes! Gorilla just released large seat, OEM spec' lugs nuts (black | chrome) ......
  1. they're SOLID (and not capped). *BTW - The FoMoCo lug nuts have stainless steel caps NOT chrome.
  2. they're guaranteed for life.
  3. the part # is 61108CXLBC
DITCH! the FoMoCo POS capped lug nuts
WRCRaptor
Great Lakes
I have also had to replace a bunch of the stock lugs. It is a two fold problem 1 is using an impact on them and even though they are stainless 2 the winter weather does not help. I ordered a complete set at $5.50 apiece so I have a few spares and only replace as needed. As for the part # I can't help you until I get home on Tuesday.
The new gorillas look cool I will have to order those since I am collecting OE beadlock wheels I have 3 as of now looking for at least 2 more maybe a set of 4.
treypal
Lord of the Raptors
Riviera TX
I have 5.
Summit racing has open narrow acorn lugs m14-2.0 that's what I use. It has basically the same contact patch as the factory lugs.
Rick if you want some factory lugs. I have a ton. Probably 50-60
Yukon Joe
Trafford, PA
Nice to finally see a stock replacement option. I bought the 7/8" acorn lug which works fine, but now I have different lugs between the two trucks.
Said to call for pricing.
Any idea how much per lug?
http://www.sfxperformance.com/parts/GOR61108CXLBC.htm
Yukon Joe
gDMJoe
Timbuk3, MI
Yukon Joe ... Any idea how much per lug?
Just checked ebay ..... $99.70 for a set of 24 (*free* shipping). *$4.15/lug nut.
EDIT: Just checked OEM lug nut price - $6.90 (retail) / $4.89 (or less wholesale).
