Lost wipers, head lights stay on more??
Lance Vincent
Knoxville,TN
Rain today
Lost wipers
no turn signals
head lights come on with switch off pos when i turn on key
traction control stabil light came on
hill dis falt light came on
fues?
relay?
I have HID bulbs and balast
I have led turn sigs in front
I have 5 star tune
Going to try and go back to stock tune first.
bstoner59
does it come in shmedium?
Orange, CA
Check the seal in the 3rd brake light. I have heard of issues where water gets in a creates all sorts of trouble.
BIRDMAN
Birdministrator
Boston
i would actually point to the HID ballasts or the LED turn signals wigging your system out long before i blamed the tune.
Lance Vincent
Lance Vincent
Knoxville,TN
I just pulled the HIDs and LEDs put stock ones back in.
Did not fix problem.
---------- Post added at 06:21 PM ---------- Previous post was at 06:10 PM ----------
ust pulled 3rd brake light = yes has water in light. center led looks like it has burn spots around led.
Squatting Dog
Kansas City, MO
Water was causing stray voltage to ground, back feeding through hid ballasts causing lights to stay on..
-Greg
Squatting Dog
Kansas City, MO
3rd brake light also has a lota green build up around LEDs
The green build up is oxidation on the circuit board. Kindof like rust.. I would suggest a trip to stealership and have it replaced under warranty, along with the gasket. Otherwise it will eventually leak bad enough to ruin your headliner (you might want to check for dampness, before going to dealer)
-Greg
Badrap
Mabank, Texas
Dang! I noticed moisture in one of my rear lights yesterday and now I read this. My top center light with the LED's burnt out two months ago.
Crappy seals.
Lance Vincent
Lance Vincent
Knoxville,TN
45412 miles looks like im going to pay
---------- Post added at 07:34 PM ---------- Previous post was at 07:32 PM ----------
Why would i have lost every thing on the turn signal stalk?
no wipers
no high beams
no signals
also hill desnt fault
and traction fault
Squatting Dog
Kansas City, MO
Modern serial communication and control systems have created a solution for these problems, and that's the steering column control module, a single component that integrates all the functions of those many individual pieces. The amount of wiring is reduced, reliability is up thanks to new electronic techniques supplanting older wear-prone designs. The module includes all sorts of stuff like headlamp switches, turn signals, tilt/telescope control, hazard lamps, steering angle sensor and electronic turn signal cancel, which is unique to the new Ford modules.
Because there was a fault to ground in the lighting CAN-bus circuit, it effects everything on that circuit (system)
I am sure one of the Ford gurus can help clarify or correct me.
-Greg
