Raptor Air Oil Catch Can
justvettn
justvettn
GTA
Does any one know what two bolts the bracket mounts to on the Moroso unit?
justvettn
justvettn
GTA
Have you seen any pictures of them mounted and do you know what bolts or studs they get mounted to?
justvettn
justvettn
GTA
Hey thanks Greg, your the best! Have been scouring the net looking for pictures of this setup mounted. I like it, lots of room to service it and clean looking install. I think I might order one.
SVT_4X4
Linden, MI
I am looking for a setup for my Raptor. I have a ProCharger on it and did not really like their setup as they blocked off the passenger side, and then just vented the driver side and ran into the air cleaner before the supercharger. Up at the SnoBall 500 event actually had enough moisture in the tube that it froze up. Had to clean it out. If I am turning some RPM's I will get a bit of moisture with oil. I will contact JLT to see what they can help with.
Also someone mentioned Ethanol and that it should help, but it will actually hurt and does cause more moisture and oil contamination.
Reptar
Jersey
The thing with that moroso, there's a longer drain pipe coming off past that valve. Looks to be about 2". When you shut the valve off there's still going to be some residual oil in that line and it'll drip out over time making a mess. Unless that little red cap stays on, but it's another thing to lose or fall off. And you have to make sure there's room below it to fit a container to drain it into, always need a container on hand to drain it in, and it's got rubber hoses running to/from. The JLT eliminates all those small inconveniences.
