RaptorVette
Today I installed a 48" tool chest made by Promaxx. I've had the Bakbox for a year and it fell down recently so I started searching for a better solution. I came up with this and thought I'd share since I haven't seen anything like this on here.
Step 1: Measure and drill holes. Note the fuel filler neck just under the bed a few inches from where I drilled the holes.
[/URL][/img]
[/URL][/img]
[/URL][/img]
Screw drivers showing where the holes are:
[/URL][/img]
Step 2: Bolt tool box to the bed. I ran the bolts through from the bottom to protect the treads and locking nuts. I got stainless steel 3/8" hardware, locking nuts, washers and rubber washer between the tool box and the bed.
[/URL][/img]
[/URL][/img]
[/URL][/img]
Step 3: Load it up with all my shit! I've got a 3 ton jack, traction ladders, tools, tow rope and other misc. stuff. I'm surprised how much I got in there.
[/URL][/img]
[/URL][/img]
Finished!!! The lid does not open 90 degrees because of the bed cover but I have plenty of room to get everything in and out without being mounted against the wall of the bed. I also coated the bolt heads under the bed with bed liner.
[/URL][/img]
