Ok... So I've put off posting about my bumper for some reason or another, but want to kind of give some feed back as to how I built it.
I built my bumper back in 2010ish maybe first of 2011 I didn't like how the bumpers that were out took the stock tow hooks away which to me didn't seem like the best idea. I wanted something that looked good but didn't take to much away from the truck. I came up with an image i wanted to go with that flowed well and added on from there. I will have to give my father some credit for helping me get this thing going and added a few ideas on how to get started.
I only used a few tools that are pretty easy to find and fairly easy to use.
Some of them include: welder, plasma cutter, grinder, wire brush, drill, drill bits, wrenches to take stock bumper off and put the new one on, tape measure, some cardboard, a few sharpies, quarters, string, pipe stands, ply wood, cheap pipe bender, black tape, and some synthetic sand.
Ok for the start and yes I pretty much suck for write ups.... I'm a little scatter brained.
Here is what the original idea was going to be:
Then after that look I tried to closely match it. Not having a little welding or plasma cutter at my personal house I started this project back at the parents.
This is where the ol' man comes into play for helping me with starting off. I took off the stock bumper and found what I was going to be working with. So I made plates to work off:
The easiest way I could think of how to "jig" up haha was with stands and ply wood. I used one of my HID lights and put on the ply wood where I wanted it placed compared to the rest of the truck. I then took a string and quarters and marked where I was going to put bends in the pipe with my cheap harbor freight bender.
Like this:
Then once I had it marked out I started bending the top pipe to fit the line:
Once the top pipe had all the correct bends in it to match the line that was made I took out the ply wood and had the pipe stands hold the pipe in place for attachment points to be made:
Then cut out some cardboard for a template to make the actual plate metal for the attachment point:
Ones your pipe is welded to the the attachment plates you can fill the side plates in. I used more cardboard to get a good match to the rest of it:
Once they are all on there thats when I put in a draw bar to hang the lights from on the back side of the 2" main frame pipe:
Then after that I drilled holes for the lights, but making sure I had room for my upright 1" bars I started on the top baja looking bar:
This is the bender I used and to make the bends not deform I filled it with bauxite due to sand was crushing on the 2" main bar and the angles weren't near as much. The 4130 chromoly pipe was that strong:
Here it is tacked up to the 2":
After that is attached I started to finish it out with the support 1" bars to the upper loop:
I welded in tabs for the skid plate and cut it out to fit flush but don't really have good pics of that. Also, I put in a brace bar from the outer edge back to the frame to really add strength to the front end. Once that was all finished I sanded it down and just spray painted it before powdercoat just to make sure i didn't want to change something about it.
Here it is before paint:
![37141_568251433124_3259192_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-ash3%2F37141_568251433124_3259192_n.jpg&hash=4f4f7ffe424b0fb1309aeb4c83af3305)
![75730_568251453084_5832672_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F75730_568251453084_5832672_n.jpg&hash=89f0f4a573f64b1de0b26402ea18664c)
![150314_568251478034_51083_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-ash3%2F150314_568251478034_51083_n.jpg&hash=12353bb2137f112ead4ba738814fb38b)
![149097_569548209374_1498278_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-ash3%2F149097_569548209374_1498278_n.jpg&hash=3f744a37803579d85afa0fa4649b0dc2)
![73210_569548249294_6789271_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F73210_569548249294_6789271_n.jpg&hash=ea7e0967fcf7c18dc68f0ff63c85f54d)
![76835_569548259274_3614057_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-ash3%2F76835_569548259274_3614057_n.jpg&hash=4c493130aa14edb84d4b5de4f6051164)
Like this:
![76945_569548284224_2517421_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-prn1%2F76945_569548284224_2517421_n.jpg&hash=d3f8e710f4e03666975ad74330867845)
![76263_569548294204_195195_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-prn1%2F76263_569548294204_195195_n.jpg&hash=2964c6f679d0cebf10e3df7b03af1574)
![76901_569548309174_7062312_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F76901_569548309174_7062312_n.jpg&hash=b1ad062bfb6a0a205db49f02f113a6bf)
![76793_569548329134_152690_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-ash3%2F76793_569548329134_152690_n.jpg&hash=f623aff92be71f9aec93c8e59618fcf9)
![74339_569548319154_7252784_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-ash3%2F74339_569548319154_7252784_n.jpg&hash=a6620fe0dbab2849444e83b493e1a7d1)
![74221_569548344104_7867459_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F74221_569548344104_7867459_n.jpg&hash=d697c97a0de482fbaf59d0ee9e5304b2)
![74207_569548354084_2444201_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-prn1%2F74207_569548354084_2444201_n.jpg&hash=2a89d3a7c4b6715ff06f55bfc7409f9a)
![76419_569548398994_3295627_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-ash3%2F76419_569548398994_3295627_n.jpg&hash=afcec52511be5b88744e7fe149c33cf6)
![39603_569548389014_6204482_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-ash3%2F39603_569548389014_6204482_n.jpg&hash=03292b4dadca34e8f7235b192c87aa96)
![76228_569548374044_951235_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-ash3%2F76228_569548374044_951235_n.jpg&hash=9d92b7c43830b7c6fd5c0fbf3cde4941)
![76803_570315147424_1521390_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F76803_570315147424_1521390_n.jpg&hash=04be6c916b9a01d47c81e8c1b88e7dd5)
![76168_570315072574_4701214_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-prn1%2F76168_570315072574_4701214_n.jpg&hash=c45bfd4c09ab4badb33d37f5de673e8e)
![155643_570315127464_4633447_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F155643_570315127464_4633447_n.jpg&hash=dd8e6483ad95c8957cfe2b5d55e4177b)
![76325_570315177364_6372275_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F76325_570315177364_6372275_n.jpg&hash=43589a653142458d0d4a6f29319289c2)
![73970_570315222274_4960626_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-prn1%2F73970_570315222274_4960626_n.jpg&hash=4a85ee5741df8d3cccfa3bb0ad57add8)
![74873_570315272174_1067166_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F74873_570315272174_1067166_n.jpg&hash=44b360b55119496f1114b7f0f84d1695)
![156607_571540846114_8196822_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-prn1%2F156607_571540846114_8196822_n.jpg&hash=74d12b4425ac49b5d4a038fa9024d9eb)
![156294_571540866074_5304447_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F156294_571540866074_5304447_n.jpg&hash=4233c8597f5a739f87f49ddffce833c0)
![150064_571540876054_2625385_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-ash3%2F150064_571540876054_2625385_n.jpg&hash=db57f255223bd97627c87897c09d38ac)
![77140_571541414974_4437958_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-ash3%2F77140_571541414974_4437958_n.jpg&hash=8fff8e35a7212e05780c0053d9b889a5)
![69496_572814798104_2288549_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-b.xx.fbcdn.net%2Fhphotos-prn1%2F69496_572814798104_2288549_n.jpg&hash=723ca1a26a20546a30a69398e2942bf1)
![63414_572814813074_3435187_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-prn1%2F63414_572814813074_3435187_n.jpg&hash=772f50dae2d86be40d1d5b85a7697031)
![155172_572814828044_5183120_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-ash3%2F155172_572814828044_5183120_n.jpg&hash=251f13e77e36dab465f7cd6b1e6d9129)
![155589_572814848004_1143320_n.jpg](/proxy.php?image=http%3A%2F%2Fsphotos-a.xx.fbcdn.net%2Fhphotos-prn1%2F155589_572814848004_1143320_n.jpg&hash=758c87f216ba78459c8719a70cf965c3)
