Hydro dipped my 2011 dash panels
Big Blue
Administrator
Staff member
Admin
USA
That's crazy, I like it! :evillol:
And when you get tired of it, you can just re-dip with something new. Nice job.
jackrook
Bermuda Dunes, Ca
To each his own. I wouldn't go with the snake skin PERSONALLY. Doesn't look bad at all. Just not my presence design. Looks killer. I'd go with a different patter but I like what you did here.
Sent from my iPhone using Forum Runner
NiteLife
NiteLife
Fort Wayne, IN
out of curiousity, how long did it take you to remove all those trim panels?
Not long, prolly have hour or two in total disassembly. You Tube was a big help in viewing how to take it apart.
---------- Post added at 09:55 AM ---------- Previous post was at 09:52 AM ----------
Not a fan at all way too busy. Glad you like the outcome.
Well.... I'm still getting used to it. The pattern I was originally was gonna go with was little more subtle, less boldness in the black, but I will be using this as a demo of my fledgling business so I went for a larger impact design.
Evanscott29
San Diego, CA
mind linking the youtube you used? I would like to get my dash wrapped to get rid of the chrome and this stupid area that has started cracking and flaking. might be getting the dealer to give me a new piece under warranty first.
BAJASVT
SE Michigan
Which panels started cracking and flaking? Pictures?
The dash trim panels are pretty easy to remove. The panels on each side of the radio trim are the most time consuming to remove because you have to unbolt the four center console bolts and slide it back about an inch to remove those. Also, believe you have to slightly pop out the passenger airbag to get the trim piece on the far passenger side off.
