2024 build date???
ss55539
Well-Known Member
Nebraska
so now im more concerned. just got a raptor ranger in and they have an enhanced pre delivery inspection. the f150 raptors have this as well. reading through the bulletin it sounds like ALOT of mistakes could have been made. really second guessing this truck now.
  • 24U04_TECH_F150.pdf
ToadSmasher2K1
KC
My 2024 R failed No. 23, guess they didn't follow this PDI list.
RaptorJoe331
USA
Ill run down the list tomorrow. Definitely doesn't give a feeling of confidence if they need "enhanced" PDI
NickyF25
SE PA
i think the recall was just issued today. you should be able to go back and have them do the enhanced pdi
Is that a recall on the appliqué separating? Had mine on my 2023 35 replaced once after about 6 months of ownership and it is lifting again about 7 months later, a little worse this time too. Both times is the drivers side top corner.
ss55539
Well-Known Member
Nebraska
Is that a recall on the appliqué separating? Had mine on my 23 replaced once after about 6 months of ownership and it is lifting again about 7 months later, a little worse this time too. Both times is the drivers top corcorner.
No it's a recall for pdi further inspection. But if any of the items fail they have to be fixed before delivery
ToadSmasher2K1
KC
Might be better to squirt some gorilla glue down the back of the appliqué and tape it up for 24 hours. That would probably hold for a long time
Flex Seal will fix it
