2021 RAPTOR Press release
06z
So Cal
2021 Ford F-150 Raptor
  • Tackle tougher terrain: Fully redesigned F-150 Raptor boosts its off-road capability with all-new five-link rear suspension featuring improved wheel travel, electronically controlled next-generation FOX™ shocks with Live Valve™ technology, plus first-in-class* available 37-inch tires to tackle tougher terrain on high-speed desert runs
  • Most connected: Every F-150 Raptor comes with standard over-the-air updates and a new connected experience that can deliver potential features like shareable digital trail maps or other off-road technologies in the future; plus, there’s SYNC® 4 with cloud-connected navigation and voice search and the FordPass mobile app to check on your truck remotely, control the truck’s lights from your hand and more
  • Best-performing: High-output 3.5-liter EcoBoost® engine delivers better low-end torque, enables greater maximum towing and increased maximum payload capability, brings a projected EPA-estimated range of over 500 milesƗ, and class-exclusive* active valve dual exhaust for throatier engine sound; Raptor R is coming next year
DEARBORN, Mich., Feb. 3, 2021 –Ford, America’s truck leader, created an off-road icon in 2009 when it introduced the desert racing-inspired F-150 Raptor. It was designed to not only speed over rough terrain, but also to jump and catch air.
And today, it’s born again with an all-new third-generation F-150 Raptor that takes the mechanical and technical brilliance and precision of Raptor and infuses it with enhanced connected technology that means the experience of owning one will only improve over time.
“Raptor is the original desert truck. We just took it to another level,” said Ali Jammoul, Ford Performance vehicle program director. “The all-new Raptor splices high-speed off-road performance muscle with advanced technology and connectivity that comes together in a unique Built Ford Tough way.”
F-150 Raptor has eclipsed the sales of other well-known performance icons. Over the last four years, the previous-generation Raptor cumulatively outsold Porsche’s entire lineup of sports cars and also outsold Chevrolet’s Corvette.
High-performance hardware
A high-performance off-road pickup is defined by its suspension, and the all-new F-150 Raptor debuts with completely redesigned running gear. It is reengineered with an all-new five-link rear suspension developed specifically for Raptor, designed to deliver more control and power to the ground with greater confidence over rough terrain at high speeds.
“Raptor is rooted in Baja 1000 racing, and its suspension advances our capability and performance – a five-link rear setup with more wheel travel than any Raptor before it,” said Carl Widmann, Ford Performance chief engineer. “And like a trophy truck, every aspect of Raptor has been engineered to deliver precision capability when your foot is flat on the floor, way out in the middle of nowhere roaring across the desert.”
The five-link rear suspension features extra-long trailing arms to better maintain axle position on rough terrain, a Panhard rod and 24-inch coil springs – the longest in the class*. The suspension design combined with more sophisticated engine management software means the truck can put more torque to the rear wheels for quicker starts off the line, faster acceleration and better throttle responsiveness while simultaneously delivering comfort, stability, handling, control and traction at speed.
Soaking up giant whoops and landings comes courtesy of next-generation FOX™ Live Valve™ internal bypass shocks with state-of-the-art electronic control technology offering position-sensitive damping adjustability. Raptor’s largest-ever shocks are designed to better resist heat buildup and to react even faster to terrain changes for greater confidence over extended desert running. The larger 3.1-inch-diameter anodized aluminum shock bodies are filled with all-new low-friction shock fluid specially designed to decrease frictional losses inside the damper for improved off and on-road comfort. New electronically controlled base valves are race-proven with an upgraded design enabling upward of 1,000 pounds of damping per corner at desert speeds.
Readings from suspension height sensors and other sensors around the truck change damping rates independently at each corner 500 times per second, with the shocks responding at the same speed the human brain processes visual information. The truck responds by the time the driver even registers a terrain change.
For the first time, Raptor is available with either 35-inch or 37-inch tires – the largest factory-fitted to a production light-duty full-size pickup. These specially designed BFGoodrich All-Terrain T/A KO2 tires offer maximum traction and handling. Wearing 35-inch tires, Raptor clears 12-inch obstacles with an approach angle of 31 degrees, maximum departure angle of 23.9 degrees and breakover angle of 22.7 degrees. Raptor with 37-inch tires features 13.1 inches of running clearance, 33.1 degrees of approach angle, a maximum 24.9 degrees of departure angle and 24.4 degrees of breakover angle. Desert runners and rock crawlers alike will appreciate the outstanding wheel travel with 35-inch tires, reaching 14 inches at the front and 15 inches at the rear – 25 percent more travel than the first-generation Raptor.
Available in SuperCrew configuration on a 145-inch wheelbase, Raptor features a fully boxed high-strength steel frame with a high-strength, military-grade, aluminum alloy and composite body. The more capable suspension, stronger, taller shock towers and rear control arm mounting points serve to withstand punishing off-road use.
The all-new Raptor is equipped with a third-generation twin-turbo 3.5-liter EcoBoost® high-output engine delivering torque low in the rev range right where it counts. It features Raptor Audio FIle (MP3)
* Class is full-size pickups under 8,500 pounds GVWR.
** Trail 1-Pedal Drive is an extra driving aid. It does not replace the driver’s attention and judgment, or the need to apply the brakes. See owner’s manual for details and limitations.
Ɨ Range calculation based on 34.9 gallons (actual tank size 36 gallons) and a projected EPA-estimated rating of at least 15 mpg combined. Actual range will vary.
About Ford Motor Company
Ford Motor Company (NYSE: F) is a global company based in Dearborn, Michigan. The company designs, manufactures, markets and services a full line of Ford cars, trucks, SUVs, electrified vehicles and Lincoln luxury vehicles, provides financial services through Ford Motor Credit Company and is pursuing leadership positions in electrification; mobility solutions, including self-driving services; and connected services. Ford employs approximately 187,000 people worldwide. For more information regarding Ford, its products and Ford Motor Credit Company, please visit corporate.ford.com.
Related Photos
Feb 3, 2021
Feb 3, 2021
Feb 3, 2021
Feb 3, 2021
Feb 3, 2021
Jan 22, 2021
View More
Related Videos
2021 Ford F-150 Raptor Running B-Roll
Feb 3, 2021
2021 Ford F-150 Raptor Running B-Roll (sound)
Feb 3, 2021
2021 F-150 Raptor Interior and Static B-Roll
Feb 3, 2021
2021 Ford F-150 Raptor Shock Animation
Feb 3, 2021
Design Sketches
Raptor Design Sketch
Feb 3, 2021
Feb 3, 2021
View More
PDFS
Raptor Tech Specs
Raptor Enhanced Exhaust
GIFs
2021 F-150 Raptor GIF
Feb 3, 2021
Feb 3, 2021
View More
FOX™ shocks
Raptor FOX™ shocks
Feb 3, 2021
Raptor FOX™ shocks
Feb 3, 2021
View More
Media Contact
TO VIEW CONTACT DETAILS PLEASE REGISTER HERE
rtmozingo
North Texas
I like the new grille; it is a good blend of both gens. I don't like the rigid lights and their underhang, nor do I particularly love the new bumper. Overall, new front end is good. Might like it better than the previous two gens.
Back end looks ok, not great. Maybe the worst of the three?
No SuperCab :( I really wonder if the Raptor R will be a V8 SCAB as a throwback. Every R to this point has been a SCAB, so it would be heresy not to have that option IMO....
Suspension seems to be consistent with historical trends - a step change, but not necessarily a large one. I'm hearing (and seeing) very mixed reports on the TRX suspension. Physics suggests to me it can't be better than a Gen 2, but until more videos come out I can't make a strong statement. Assuming it is slightly better than the Gen 2, this would mean the Gen 3's would be comfortably better, but not by a large margin.
37s as a stock option is the most interesting thing here. The myriad of woes associated with upsizing look to be a thing of the past. I reckon it is safe to assume the Gen 3 components can handle 37s even if your order the base model, which means one could run 35s daily and then switch to 37s for offroad use without worry. That is pretty significant.
New exhaust definitely is doing its job.
06z
06z
So Cal
The 37 has a different frame. Lots of changes for the 37's to fit and frame support as well.
From Motor Trend
Time For New Frames
Ford needed two new frames for the Raptor lineup; both modified to accommodate the new five-link coil-sprung rear suspension, and one further revised to accommodate a 37-inch spare tire mounted under the bed. In fact, the 37s are part of a whole system, including wheels and tires, a different frame for the spare, different shock hardware, and different overall tuning. The standard Raptor will come on 35-inch tires, which don't get the frame modification to fit the spare.
It is a pretty big change, Ford Performance Chief Engineer Carl Widmann says: "We probably should have put a second step board on it to get down from the vehicle. When you grab the steering wheel to get in, you will notice it right off the bat. And it definitely gives it a different appearance."
Back in the day, 35s were seen as a big step. "To get a factory-delivered vehicle with 37s that is all integrated in the chassis electronics, versus what people been doing when their 35s wore out, that's why we spent time to do this," Widmann says.
Ground clearance is 12.0 inches with the standard 35-inch tires and 13.1 inches with the 37s.
rtmozingo
North Texas
From Motor Trend
Huh, interesting. I'm curious to how exactly that plays out. Anyone have pictures of the two side by side? Presumably you'd order the 37 package and then run 35s onroad if you wanted.
