- Joined
- Jul 15, 2017
- Posts
- 1,093
- Reaction score
- 984
US Utility Patent - US11699537B2
Our Harnesses use the HIGHEST Grade 200C temp rating (Which is almost 400 degrees F, vs general wiring you get that is normally heat rated at 105C (200 degrees F) We only use the HIGHEST quality materials.
Watch this heat test video-
This is how it works... We have MAIN components, Extensions, Adapters, Relays, Splitters, etc....
You can start with our ORIGINAL Switch Wire Numbered Extensions, Prep Pack or Pig Tails- (Or use the INCLUDED Add on Connectors that come with each main Harness. Pig Tails use the connectors in the harness kits)
With these, you can simply plug into any of our harnesses, splitters, etc.
Then pick your main harness-
Triple Fog- (Or 3 Pairs of lights) (16AWG Wire PER)
Single Pair Fog Harness (Or 2 Pairs of Lights) (12AWG Wire) (Handles HD Light Pairs)
Standard Light Bar Harness (12AWG Wire new model, previous 14AWG)
Short Light Bar Harness (14AWG)
HD Light bar Harness (10AWG)
A-Pillar Ditch Light Harness (12AWG)
Full Rear Harness (12AWG New Model/14AWG Previous)
Short Rear Harness WITH Tail Light Adapter (14AWG)
From there, you have adapters which will match to ANY Light Make or Model from almost ANY company. Each harness has 3 wires so if you have backlights, you can power them and if not, you just don't access that wire. Each of our harnesses INCLUDE connector packs to add to lights that don't have connectors and to your switch wires. However, you can simply select the connector style you need for the harness in the selection menu. Here are those adapters though separate so you can see them. This video explains.
DT 2 Way Adapter
DT 3 Way Adapter
DT 4 Way Adapter
WP 2 Way Adapter
The really cool thing about this system is. If you decide to change lights on your truck. No matter if it has backlights or not and no matter the brand. You don't change harnesses. You just swap out the adapters.
In fact, just like Audio/Video Cables, USB Cables, etc. You can take them with you to your next vehicle. They are FUTURE PROOF. Even if you want to change the the lights on them.
Next we have our add on relay adapter.. If you need more power than your switch provides you can just plug in this relay adapter. If not, less bulk. Just go straight to the switch wires...
From there you have a vast array of splitters. Check out this video on the splitters-
We have splitters of all sizes. Some, you can use to combine into switches or powered circuits. Others to add multiple lights to one harness end.
Now lets say you have backlights and want to connect them to work with your vehicles electrical system. Or want reverse light triggers without cutting, splicing or fuse taps. You simply add one of our Headlight, Marker Light or Tail Light Adapters.
This video explains-
Well hopefully you are catching on... because we aren't done yet.... I want to emphasize again that the main component harness NAMES are really just suggestions. Just because it says "Light Bar Harness" or "Fog Light Harness" doesn't mean you need to use it for that. It is basically a framework. So for example. Lets say you have a Chase Rack and you want to put a light bar on it. That's way back there. A normal light bar harness isn't long enough on its own... so you can make it whatever you want with our Extensions...
We have extensions for the beginning, to the switches... and at the end, to the lights. You can add an extension to BOTH ENDS on a fog harness, or to a light bar harness... Or Chase Rack or Roof.
Here they are-
I think you are getting it!!! Lets keep going!!
So for those guys who want Amber lights and Clear lights all in one harness. Sure, you can use 2 harnesses here... That's one of many options... However, we added our crossover adapter series to allow you to pull a separate connection from the 3rd wire for ONE light and a different one for the Red wire for another (When you don't have backlights on the harness). We also made a set of crossover Adapter Splitters so you can add 2 connections wit separate switches at one junction... (This is very popular for the guys with the behind the grille light kits) Check out the video!
https://www.youtube.com/watch?v=mgGx2TxVDkY&t=148s
Ok... So we are still going... Lets see what else we can do...
If you have a Rear harness that goes to the switch wires and has a tail light adapter. It can supply power to a front harness for backlights as well by plugging in this coupler and the two harnesses together.
What if you have lights that are RGBW.... They require tapping the backlight power wire on the battery to change colors.... Well, we created an IN-LINE tap switch that you can plug into our harnesses between our headlight adapters and marker or tail light adapters to easily change colors...
Ok, goodness, we aren't done yet... Lets see what else we can do....
What about factory fog connections...
We have a series of fog light adapters... Sure, that's not something completely unique for a standard 2 wire fog adapter. We do have those here.... but we also have our 3 pole adapters that have a 3rd wire for backlights. No clipping or splicing. You just interconnect with our other harnesses..
Even Splitter versions for 2 lights on ONE!
But now... how do you get that power down there to those ports for backlights?
Well, you can use our backlight Y harness-
Or if you have another harness down there in the vicinity... our backlight port tap adapters....
Ok... So we also have so many that just want to COMBINE their OEM Fog lights to one switch on their Raptors.. So we have these Molex Splitters...
But what if you want to move those connections to a central located spot to hook up a different harness to the Aux 1 or Fog switch buried in the bumper... Well you can with our relocation harness. The it can connect to any of our other harnesses-
https://www.youtube.com/watch?v=biiQMNghBek&t=77s
What if you have a Base Gen 3 Raptor and want to put take off OEM Fog lights in and connect to the Aux switches? We have a Plug N play harness for that..
We have adapters that match our harnesses to go to the Molex Connectors Ford used on the OEM Rigid lights too.
These are but a few examples of how you can plug and play your way to virtually any custom harness configuration you can imagine. Its simply about picking the right pieces....
We would love to help you with that. Whoever out there that has used our system, please chime in and let us know how you liked them!
Feel free to contact us for advice on what to order, how to configure and any help...
If you purchase any of OUR light kits...(SPV Branded) You will get our harnesses with them. Though you may want to add a few pieces to make them work with other kits, add features, etc... You will be on the road to simplicity!
John
SPV Parts
317/934/6778
info @spvparts.com
Auxiliary (Aux) Switch Wire Extension Kit with Connectors (Numbered)
SPV Parts is proud to present our new Aux Switch Wire Extension Kit. This new kit will extend your Aux switch wires in your Raptor, Bronco, Super Duty, Tremor and other vehicles by about 8 inches. In addition, each includes a single Weather Pack connector installed for quick connect to any of...
specialtyperformanceparts.com
Auxiliary (Aux) Switch Wire Extension & Pass Thru Kit with Connectors (Numbered) SPV Parts System - Ford Bronco, F-150 Raptor, Tremor, Ranger, Etc
Connector Kit for vehicles with Auxiliary Switches- Bronco/Raptor All Generation F-150 Raptors Tremor Ranger Tremor/Raptor Super Duty Jeep Others The Extensions include numbered switch wires #1-6, as well as 12 Pass through extensions labeled P1/P1 (Male and Female Connectors for both ends)...
Auxiliary (Aux) Switch Wire & Light Wire Crimp on Weather Pack Pin Pig Tail Packs
Some lights, such as the Rigid Radiance/Scene/360 don't have connectors on them. Our Plug N Play Harness System has connectors and adapters to match to virtually any light model or brand. Our harnesses come with matching connectors and pins for both lights that have bare wires, and the factory...
SPV Parts Triple Pair Fog Harness - SPV Harness System (Works with MANY vehicles, See Details)
Triple Pair Fog harness MAIN APPLICATION/DESCRIPTION- Already cut to length, just plug in 1,2,3 Lights on one side, then 1,2,3 on the other. This is a direct component harness to connect 3 pairs of lights/Fog Lights to ANY Ford Raptor, or Ford Superduty, Bronco, ETC with built in switches. OR...
SPV Parts SINGLE Pair Fog Harness - SPV Harness System (Works with MANY vehicles, See Details)
Single Pair Fog harness MAIN APPLICATION/DESCRIPTION- Already cut to length, just plug in 1 Light on one side, then 1 on the other. This is a direct component harness to connect 1 pair of lights/Fog Lights to ANY Ford Raptor, or Ford Superduty, Bronco, ETC with built in switches. OR Any other...
SPV Parts STANDARD Duty Light Bar Harness - SPV Harness System (Works with MANY vehicles, See Details)
STANDARD GAUGE LIGHT BAR HARNESS MAIN APPLICATION/DESCRIPTION- Already cut to length, just plug in a single light or light bar to your vehicle. This harness will run from one light/ Bar to the fire wall of any truck. The Standard Gauge Light Bar Harness is 14awg wire and can support up to 15...
SPV Parts SHORT Light Bar Harness - SPV Harness System (Works with MANY vehicles, See Details)
SPV Parts HEAVY DUTY Gauge Light Bar Harness - SPV Harness System (Works with MANY vehicles, See Details)
HEAVY DUTY GAUGE LIGHT BAR HARNESS MAIN APPLICATION/DESCRIPTION- Already cut to length, just plug in a single light or light bar to your vehicle. This harness will run from one light/ Bar to the fire wall of any truck. The Standard Gauge Light Bar Harness is 10awg wire and can support up to 30...
SPV Parts A-Pillar/Ditch Light Harness - SPV Harness System (Works with MANY vehicles, See Details)
A-Pillar / Ditch Light Harness Already cut to length, just plug in a pair of lights your vehicle vehicles cowl area. This harness will run from 2 lights to the fire wall of any truck. The Harness is 16awg wire and can support up to 10 amps total in general on the circuit. If you are not putting...
SPV Parts FULL LENGTH REAR Harness - SPV Harness System (Works with MANY vehicles, See Details)
2017-2019 Raptor Custom fog harness for Rigid Industries D-Series Pro fog lights! Don't worry about messing with the wiring yourself, let us do it for you! Pick up your fog harness and join the SPV family today!
SPV Parts SHORT LENGTH REAR Harness w/ Taillight adapter - SPV Harness System (Works with MANY vehicles, See Details)
SHORT LENGTH REAR LIGHT HARNESS - Includes Tail Light Adapter MAIN APPLICATION/DESCRIPTION- Already cut to length, just plug in a pair of lights in the REAR of your vehicle. This harness will run from one rear light, to the other rear light and out to a pair of connections that you will simply...
SPV Parts Harness 2 Pole DT Connector Adapters (Single) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way DT Connector Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the 2 way DT connectors. Typically Rigid Industries Pro Series as well as others. Harness System Description- This harness is part of our UNIVERSAL harness system...
SPV Parts Harness 3 Pole DT Connector Adapters (Single) - SPV Harness System (Works with MANY vehicles, See Details)
3 Way DT Connector Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the triangular DT 3 Way connectors, and connects to the SPV Universal Harness System. Typically Rigid Light Bars. Harness System Description- This harness is part of...
SPV Parts Harness 4 Pole DT Connector Adapters (Single) - SPV Harness System (Works with MANY vehicles, See Details)
4 Way DT Connector Adaptor (To Universal Harness System) (3 Wires for Diode Dynamics lights WITH Backlights) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the square DT 4 Way connectors, and connects to the SPV Universal Harness System. Typically Diode Dynamics. These...
SPV Parts Harness 2 Pole WP Connector Adapters (Single) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way WP Connector Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the 2 way Weather Pack connectors. Typically Baja Designs Pro/Sport/Racer Series Single Stage (Not backlit) lights as well as others.
SPV Parts Harness RELAY/FUSE Add on Adapter - SPV Harness System (Works with MANY vehicles, See Details)
Relay and Fuse Add on Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with ALL of our Universal Harness System Harnesses. If you need to add a fuse and relay to an application because you either don't have built in relays/fuses in a factory switch panel like the Raptor...
SPV Parts Harness 2-way Splitter or 3-way Splitter (Single Pole) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way/3 Way Splitter Adapters MAIN APPLICATION/DESCRIPTION- Use these splitters for the following applications with our universal harness system- 2 Way Splitter - Use to combine a pair of wires or split a pair of wires 3 Way Splitter - Use to combine or split 3 sets of wires Examples would be-...
SPV Parts 2 Way HARNESS Splitter with 3 Pole WP Connectors (Single) - SPV Harness System (Works with MANY vehicles, See Details)
SPV Parts 3 Way HARNESS Splitter with 3 Pole WP Connectors (Single) - SPV Harness System (Works with MANY vehicles, See Details)
4X 3 Pole HD Chain Harness Splitter add on - SPV Harness System (Works with MANY vehicles, See Details)
4X Chain HD - 3 Pole WP Connector (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- This harness is intended to be plugged into our Standard Duty or HD Light Bar Harnesses. You will need to add one of those as well, unless you already have one. Our Standard Duty Light Bar Harness is 14...
6X 3 Pole WP Connector Harness Splitter add on - SPV Harness System (Works with MANY vehicles, See Details)
6 Chain - 3 Pole WP Connector (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- This harness is intended to be plugged into our Standard Duty or HD Light Bar Harnesses. You will want to add one of those as well, unless you already have one. Both this and our Standard Duty Light Bar...
8X 3 Pole Chain Harness Splitter add on - SPV Harness System (Works with MANY vehicles, See Details)
8 Chain - 3 Way DT Connector (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- This harness is intended to be plugged into our Standard Duty or HD Light Bar Harnesses. You will and to add one of those as well, unless you already have one. Both this and our Standard Duty Light Bar...
8X 3 Pole HD Chain Harness Splitter add on - SPV Harness System (Works with MANY vehicles, See Details)
8 X Chain HD - 3 Pole WP Connector (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- This harness is intended to be plugged into our Standard Duty or HD Light Bar Harnesses. You will need to add one of those as well, unless you already have one. Our Standard Duty Light Bar Harness is...
6X 2 Pole WP Connector Harness Splitter add on - SPV Harness System (Works with MANY vehicles, See Details)
6 Chain - 2 Pole WP Connector (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- This harness is intended to be plugged into our Standard Duty or HD Light Bar Harnesses. You will want to add one of those as well, unless you already have one. Both this and our Standard Duty Light Bar...
6X 2 Pole DT Connector Harness Splitter add on - SPV Harness System (Works with MANY vehicles, See Details)
6 Chain - 2 Pole DT Connector (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- This harness is intended to be plugged into our Standard Duty or HD Light Bar Harnesses. You will want to add one of those as well, unless you already have one. Both this and our Standard Duty Light Bar...
2 Pole DT Connector HARNESS Splitter (Works with 2021- 2022 Raptor OEM FOG Connector Adapters & Others) (Sold in Singles)
2 DT Connector Splitter MAIN APPLICATION/DESCRIPTION- Connects to any 2 way DT connector and splits it to connect 2 lights. Also used in the factory fog connection in the Gen 3 Raptor to split 2 lights on one connection with our factory fog adapters. Plugs directly into an aftermarket light. The...
2 Pole Weather Pack HARNESS Connector Splitter (Works with 2021- 2024 Raptor OEM FOG Connector Adapters & Others) (Sold in Singles)
2 Weather Pack Connector Splitter MAIN APPLICATION/DESCRIPTION- Connects to any 2 way Weather Pack connector and splits it to connect 2 lights. Also used in the factory fog connection in the Gen 3 Raptor to split 2 lights on one connection with our factory fog adapters. Plugs directly into an...
SPV Parts Harness System - Raptor Parking/Marker Light Connector Adapter (Powers Aftermarket Backlights w/ Parking/Markers) (Works w/ MANY vehicles)
Raptor Backlight/Marker Light Adapters (Watch the video) MAIN APPLICATION/DESCRIPTION- These add on adapters connect to the factory harness under the plastic radiator cover. It simply plugs in between the factory harness and then connects to any of our Universal harnesses. This allows seamless...
SPV Parts Harness System Bronco (& Bronco Raptor) Parking/Headlight Connector Adapter (Powers Aftermarket Backlights w/ Parking/Markers) (Works w/ MANY vehicles)
SPV Parts Harness Taillight Connector Adapter (Powers Reverse Lights/Backlights) - SPV Harness System (Works with MANY vehicles, See Details)
Tail Light Adapters MAIN APPLICATION/DESCRIPTION- These add on adapters connect to the factory tail lights of MOST vehicles. (More makes/models coming soon) You simply plug the adapter into your tail light, and the factory harness into it. The other end connects to our FULL LENGTH Rear Harness...
SPV Parts Harness System 2021+ F-150 (& Tremor) LED Headlight Parking/Headlight Connector Adapter (Powers Backlights)
F-150 (Lariat up) (& Tremor) Backlight - Parking Light/ Headlight Adapter NOTE: This version is for the LED Headlight in the Tremor and Lariat and UP. This unit, similar to our Bronco Parking/Headlight adapter, and Raptor Marker adapter. It powers your Amber Backlights (and/or Red rear if you...
SPV Parts Harness System 2021+ Dodge Ram 1500 & TRX LED Headlight Parking/Headlight Connector Adapter (Powers Backlights)
21+ Dodge Ram 1500 & TRX Backlight - Parking Light/ Headlight Adapter NOTE: This version is for the LED Headlight in the Ram 1500 including the TRX This unit, similar to our Bronco Parking/Headlight adapter, and Raptor Marker adapter. It powers your Amber Backlights (and/or Red rear if you have...
SPV Parts Harness System Bronco SPORT (SUV/NOT FULL SIZE) Parking/Marker Connector Adapter (Powers Aftermarket Backlights w/ Parking/Markers)
Bronco SPORT (SUV.. Not the Full Size) Backlight - Parking Light/ Marker Adapter This unit, similar to our Raptor Parking/Marker light adapters powers your Amber Backlights (and/or Red rear if you have a full length harness). However, this one does it from the Fender connector rather than the...
SPV Parts Harness System Toyota Tundra/4Runner Headlight Parking/Headlight Connector Adapter (Powers Backlights)
Here they are-
SPV Parts Harness 6 Foot HD Extension with 3 Pole Connectors (To Lights etc) - SPV Harness System
This 6 Foot Extension is designed to add to the SPV Harnesses at the light end or final connection. If your harness is too short to reach the area you need to get to, this extension will add 6 foot of length to the end. If you need more length, you can stack multiples of these extensions to...
SPV Parts Harness 3 Foot Extension with 3 Pole Connectors (To Lights etc) - SPV Harness System
This 3 Foot Extension is designed to add to the SPV Harnesses at the light end or final connection. If your harness is too short to reach the area you need to get to, this extension will add 3 foot of length to the end. If you need more length, you can stack multiples of these extensions to...
SPV Parts Harness 3 Foot Extension with Single Pin Connectors (To Switches) - SPV Harness System
This 3 Foot Extension is designed to add to the SPV Harnesses at the SWITCH or TRIGGER end. Typically in an engine bay. If your harness is too short on the engine bay side (For example an extra long Crew Cab truck with 8 foot bed with our full length rear harness) and you need to extend it to...
SPV Parts Harness 4.5 Foot Backlight Extension with Single Pin Connectors (To Switches) - SPV Harness System
This 4.5 Foot Extension is designed to extend one single wire for backlights (White Wire) This is the same harness included with our Bronco headlight adapter, which brings the connection from the Grill to the Switch Wire area. It is also used to bring our Bronco Grille Marker lights harness to...
SPV Parts Harness 2 POLE WP Connector CROSSOVER Adapters (Pair) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way WP Connector CROSSOVER Adaptor (To Universal Harness System) (Pair) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the 2 way Weather Pack connectors. Typically Baja Designs Pro/Sport/Racer Series Single Stage (Not backlit) lights as well as others. NEW CROSSOVER...
SPV Parts Harness 2 Pole DT Connector CROSSOVER Adapters (Pair) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way DT Connector CROSSOVER Adaptor (To Universal Harness System) (Pair) MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the 2 way DT connectors. Typically Rigid Industries Pro Series as well as others. NEW CROSSOVER SERIES- The new crossover adapters use the secondary...
SPV Parts Harness 2 Pole DT Connector CROSSOVER Adapter SPLITTERS (Pair) - SPV Harness System (Works with MANY vehicles, See Details)
2 Way DT Connector CROSSOVER Adaptor SPLITTERS (To Universal Harness System) (Pair) SPLITTERS- Access 2 pairs of lights on ONE harness with 2 separate switches MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the 2 way DT connectors. Typically Rigid Industries Pro Series...
SPV Parts Harness 2 Pole WP Connector CROSSOVER Adapter SPLITTERS (Pair) - SPV Harness System (Works with MANY vehicles, See Details)
SPV Parts Harness Coupler - SPV Harness System (Works with MANY vehicles, See Details)
Coupler Adapter MAIN APPLICATION/DESCRIPTION- Use these splitters for the following applications with our universal harness system- Coupler Adapter - Use to connect 2 harnesses together to share power Examples would be- An Example of the coupler would be to plug in the white wire from the rear...
SPV Parts Harness Tap Switch for RGB Color Change - SPV Harness System (Works with MANY vehicles, See Details)
In Line Tap Switch MAIN APPLICATION/DESCRIPTION- Use these for the following applications with our universal harness system- In Line Tap Switch for Rigid RGB Lights Examples would be- This inline tap switch allows you to change backlight colors by tapping it and entering a program mode. This...
2021-2024 Ford F-150 Raptor OEM FOG Connector (Pair) to 2 Pole Weather Pack Adapter (Baja Designs Squadron, S2, S1)
2 Way DT Connector Adaptor to Factory FOG connector MAIN APPLICATION/DESCRIPTION- Works with Various Series Lights that use the 2 way DT connectors. Typically Rigid Industries Pro Series, SAE, (Not backlit) lights as well as others. These will plug into the factory fog light connectors of Ford...
2021-2024 Ford F-150 Raptor OEM FOG Connector (Pair) to 2 Pole DT Connector Adapter (Rigid D-Series, Diode Dynamics)
2021-2024 Ford F-150 Raptor OEM FOG Connector (Pair) to 3 Pole Weather Pack Adapter / Backlight Port (Diode Dynamics/Radiance)
2021-2024 Ford F-150 Raptor OEM FOG Connector (Pair) to DOUBLE 3 Pole Weather Pack Adapter / Backlight Port (Diode Dynamics/Radiance)
DOUBLE 3 Way Weather Pack Connector Adaptor to Factory FOG connector (21+ Raptor) MAIN APPLICATION/DESCRIPTION- Connects to the factory fog connection in the Gen 3 Raptor. Plugs directly into an aftermarket light that has 3 wires. Such as Rigid Radiance or Diode Dynamics with Backlight. This...
SPV Parts Backlight Y Harness - SPV Harness System (Works with MANY vehicles, See Details)
Backlight Y-Harness with dual connections on each side MAIN APPLICATION/DESCRIPTION- Use this harness for the following applications with our universal harness system- Power backlights on OEM style Fog Adapters by SPV with access port. Examples would be- OEM Fog Connectors on H11 or 2 pin Molex...
3 Pole to 3 pole WP Connector Adapter with Backlight Port Tap (Pair)
3 Pole to 3 pole WP Connector Adaptor Kit WITH BACKLIGHT PORT tap This adapter is designed to plug into any of our harnesses to share the white wire for backlights to another fog adapter with backlight port. This eliminates the need to add an additional harness for backlights when using a...
3 Pole to 1 pole WP Connector Adapter Backlight Port ONLY (Pair)
3 Pole to 1 pole WP Connector Adaptor Kit WITH BACKLIGHT PORT tap This adapter is designed to plug into any of our harnesses to convert the 3 Pole connector to just 1 single pole white wire for backlights to another fog adapter with backlight port. This eliminates the need to add an additional...
2-Way Raptor OEM Fog Connector Splitter (F-150 & Bronco Raptor OEM FOGS combine both pairs to 1 switch) (Pair)
2 Molex Connector Splitter MAIN APPLICATION/DESCRIPTION- If you have an F-150 or Bronco in the Raptor trim. These splitters allow you to combine BOTH of the OEM Ford/Rigid fogs together to either the fog switch or aux 1 switch. This frees up the other. We recommend our switch wire relocation...
SPV Parts 2021-2023 Ford Raptor GEN 3 Aux 1 & Fog Switch Relocation Plug N Play Harness
This small harness lets you take back your switch wires! If you purchased an 801A Raptor with the factory Fog Lights, your Aux 1 wire and the fog switch wire are stuck, relocated down to the bumper. This makes it difficult to connect them to other harnesses, such as our triple harness. Or maybe...
2021-2023 Ford F-150 & Bronco Raptor GEN 3 OEM Fog Plug N Play Conversion Harness
This harness was designed for those who have an 800A Gen 3 Raptor WITHOUT the Factory Rigid/Ford fog kit, but want to install an OEM set from an 801A Raptor into their truck. Also for any Bronco Raptor to add the OEM Rigid Fogs to your Aux switches. This harness has 4 connectors at one end...
SPV Parts Harness 2 Pole MOLEX Connector Adapters for Ford OEM Rigid Fogs (Pair) - SPV Harness System (Works with MANY vehicles, See Details)
2 Pole MOLEX Connector Adaptor (To Universal Harness System) MAIN APPLICATION/DESCRIPTION- Works with OEM Fog Lights from the Ford or F-150 Raptor (Gen 3) For those who are converting over a bumper or Ford Branded Fog Lights into a NON Raptor and are looking for a way to connect them. These...
John
SPV Parts
317/934/6778
info @spvparts.com
