- Joined
- Jul 15, 2017
- Posts
- 1,092
- Reaction score
- 984
(*Price Match Guarantee - See below)
Upcoming & Scheduled Black Friday Sales (By Vendor):
SPV Parts
(11/19-12/04)
Extra 10% Off Everything
Baja Designs
(11/24-11/27)
Up to $150 Rebate
KC Hilites
(10/31-11/15)
10% Off Everything
Morimoto Black Friday Sale
(11/20-11/28)
20% Off Everything
Diode Dynamics Black Friday Sale
(11/20-12/01)
15% Off Everything
Form Lighting Black Friday Sale
(11/20-12/01)
10% Off Everything
Roush Black Friday Sale
(11/20-11/30)
Up to 15% Off Select Items
*Select ADD Bumper or Rack purchases receive a $100 gift card 11/7-12/4
Other Door Busters, one time and clearance deals will be added HERE daily!
CLICK THE LINK BELOW FOR UPDATES AND NEW OFFERS!
Click HERE for Door Buster and One Time Deals Page
*Up to 20% Rebate on Rigid Radiance/Scene Lights
Purchase any non RGBW Radiance/Scene Pod light/s or light bar/s and get 15% back under $499 or 20% back over $499.
Click HERE for details (Link to Rebate Form)
*Up to $150 Rebate on Baja Designs Lights
RETAIL CUSTOMERS ONLY - VALID ON ORDERS PLACED BETWEEN 11-24-23 TO 11-27-23
*(Exclusions Apply)
Price Match Policy –
During the holidays we want to be sure customers not only get the best PRICE, but also the best PRODUCTS.
If you think you find a better price on a COMPARABLE product or kit at an authorized competitor.
CONTACT US at: [email protected] or call or text 317/934/6778
We will attempt to meet or beat that offer for you. We can do this 99% of the time.
Not only will we be able to provide a comparable price or better, but you will also get better components in most cases with our kitted items.
While in many cases, you may find the same things such as light brands (Rigid, Baja Designs, Diode Dynamics, Morimoto, etc) within competitors kits. The other items supplied are NOT the same.
When we claim to have the BEST Harnesses and Brackets in the industry. There is a reason and we can back it up.
We will check, make sure you are getting the best deal. If you are, we can confirm it. If not, we will be sure you do. So you have nothing to lose.
Harnesses –
Our harnesses are FULLY patented and you will not find ANYTHING comparable out there. To fully patent a product, it must be COMPLETELY unique. Not only are our harnesses and harness system the only completely modular automotive harnesses around. So they can plug together, interconnect and work with virtually any vehicle, light brand or even components in the vehicle such as running lights and reverse triggers. But they are also of the ABSOLUTE Highest grade.
If you don’t know what you are looking for, you may never know the difference. However, we will illustrate some key things to look for.
First, we use INDUSTRIAL Grade High Temp wiring. This wiring is the same grade or higher that comes in your vehicle and commercial vehicles. It is rated 200 deg Celsius. Which is equal to about 390 degrees Fahrenheit. Competitors use standard “Automotive Wiring” which has a temperature rating of 105 degrees Celsius. Which is equal to 200 degrees Fahrenheit. That means our harnesses can withstand almost 2X the temperature of the standard grade wiring used by the competitors. In addition, the coating used in our harnesses is flame retardant. Where the standard grade wire insulation used by competitors actually burns. (You can see this in our video demonstration)
Next, is the coating used to protect the harnesses. The first line of defense. We use a HIGH TEMP Loom and manufacture grade harness wraps. Competitors use lower grade PVC tubing or worse yet, braded wraps. You will notice this wrap because you can see the wire through it. These PET sleeves are intended for INTERIOR use. Not exterior where heat and other factors come into play. If your vehicle manufacture didn’t use it in your engine bay, then there is a reason. So why do others use this for exterior harnesses? Simple answer. IT’S CHEAP. We only use the HIGHEST quality wire, loom, and connectors.
US Patent: US11699537B2
Brackets –
We feel our brackets are of the highest quality, fit and finish as well. This is because we spend hundreds of ours making sure the fitment and adjustability is better than ANYTHING else out there. We often take longer to bring something out because we don’t put anything out that is not PERFECT. We guarantee the fit and adjustability will be as good or better than ANYTHING comparable.
Quality wise, we only use stainless steel for our brackets and hardware. While others may use mild steel, or even if they do use stainless steel on the brackets. They often shortcut with “Zinc Coated Steel” hardware. Of course they won’t advertise this. You will see the rust though at some point.
Our brackets are so well thought of, we even produce some for companies like Rigid Industries.
Check out the Durability test video on our harnesses.
SPV Parts
(11/19-12/04)
Baja Designs
(11/24-11/27)
Up to $150 Rebate
KC Hilites
(10/31-11/15)
10% Off Everything
(11/20-11/28)
20% Off Everything
(11/20-12/01)
15% Off Everything
(11/20-12/01)
10% Off Everything
(11/20-11/30)
*(Exclusions Apply)
Harnesses –
Brackets –
