Need help
Donovan
DC
I wish i could help with the swirls but that last time I tried that shit, I burned a hole in my clear LMAO!
GLT
DFW
The best single stage polish IMO is Sonax Perfect Finish. It's a medium cut that finishes like an ultra fine. That said, if the VSS with an orange pad didn't get those out (I can't really tell how deep they are in the photos), then the Perfect Finish may not either and you may have to use a heavy cut. If so, I've had great results from Rupes DA Coarse -- it has successfully removed deep clearcoat scratches for me, and those swirls you have will be light work for it. I'd try the Perfect Finish on one panel, see how it looks, and if it doesn't get them, go Rupes DA.
raptordoke
raptordoke
Lakeland, FL
Thanks!! I may try these out … and I am in FL … green swamp and richloam are in my backyard and Ocala isn’t too far away
MDJAK
NY
If you had no success first time around, I'd be leary of trying again. if it kills you as you say, then take it to a professional and maybe consider PPF. I find it best not to look too close.
The first set of pics look great.
OEMPlus Raptor
OEM preferred....
Oxnard CA
I vote for Sonax Perfect Finish as well. Try it with a Rupes yellow foam pad or maybe there yellow wool pad. Then little by little start upping your game and start tossing the Chemical Guys stuff in the trash.
Keshka
Summerville, Oregon
also from a similar problem on a black Pontiac Bonniville. Use a softer finish wax to get rid of swirl. Hard base wax/coating then soft wax finish coat next day
NinjaRaptor
Florida
Congrats on the truck... join the FL Raptor group in FB. Raptor Run in Ocala runs every other month or two months depends on organizer.
Pnwrider
Pnw
Skip the foam pads and go to straight wool. I have gotten amazing results from rupes yellow wool pad and coarse/fine finish depending on depth of scratches/swirl marks. I have tried just about everything over the years (da, forced rotary, Adam’s, chemical guys, griots, etc) and the rupes system can make any novice look like a pro. My go to now is the yellow wool pad and finish with favorite wax/sealant.
