GEN3 FORSCAN Autostart disable not working? Anyone have success?
Renomaan
I did the autostart disable and it worked for about a day, now it doesnt. Truck engine stops at lights, however disable switch is not illuminated and doesnt effect it now.
I did a reset to AB using the button on the bottom of the module (in forscan) No Change?
How do I reinstall or point FORSCAN to the as built file I saved before changing anything?
WTX
The Permian Basin
Last I heard forscan auto start stop will not work on a gen 3. I tried all variations on mine and it did not work.
Just get it tuned and you’ll be the best of both worlds. No start stop and more power .
Hush Car Audio
Aubrey, TX
I believe that start/stop is the same as the F150 and you can pull the power at the battery by removing a single plug.
R
Renomaan
Pretty sure, the 2023 Raptor is considered a GEN3
As far as I know the different Gens refer to the body style re
GEN1 early first Raptory body V8 builds
GEN2 6 bangers 2017? up to 2019
Gen3 6 & 8cyl 2020-2023
Each one had a distinctive body that changed on the next Gen
Correct me if Im wrong
