GEN 2 Ford Motor Company Issues Two Safety Recalls and a Safety Compliance Recall
ddpt
https://media.ford.com/content/ford...y-recalls-and-a-safety-compliance-recall.html
Nov 14, 2019 | DEARBORN, Mich.
DEARBORN, Mich., Nov. 14, 2019 – Ford Motor Company is issuing two safety recalls and a safety compliance recall in North America. Details are as follows.
Safety recall for select 2019-20 Ford F-150 vehicles for improperly secured positive battery-terminal fastener
Ford Motor Company is issuing a safety recall for select 2019-20 Ford F-150 vehicles for a positive battery-terminal fastener that may not be secured due to wiring eyelet adhesive on the surface area of the terminal joint contact for the battery-monitoring sensor. An attachment that is not secure may result in intermittent or inoperative vehicle systems, affecting instrument panel displays, braking or steering assist, or causing the engine to stall. This condition could also create a resistive short, increasing the potential for smoke, melting or risk of fire.
Ford is not aware of any reports of accident or injury related to this condition.
This action affects 135,725 vehicles in the U.S. and federal territories, 30,073 in Canada, and 2,257 in Mexico.
Affected vehicles were built at Dearborn Truck Plant from July 15 to Oct. 1, 2019, and at Kansas City Assembly Plant from June 24 to Oct. 1, 2019.
Dealers will inspect the positive battery cable joint for excess sealant adhesive. If present, dealers will remove excess adhesive, reassemble the joint and torque the fastener to specification. The Ford reference number for this recall is 19S40.
Safety recall for select 2016-17 Lincoln MKX vehicles with 3.7-liter engines
Ford Motor Company is issuing a safety recall for select 2016-17 Lincoln MKX vehicles with 3.7-liter engines. In affected vehicles, the battery cable harness may have substandard clearance, which could allow the harness to contact the transmission shifter cable bracket. Contact between the battery cable harness and the transmission shifter cable bracket could wear through the insulation of the cable, resulting in the cable shorting to ground, increasing the risk of overheated or melted wiring, as well as fire.
Ford is not aware of any reports of accident or injury related to this condition. Ford is aware of three vehicle fires potentially related to this issue.
This action affects 54,411 vehicles in the U.S. and federal territories and 5,253 in Canada.
Affected vehicles were built at Oakville Assembly Plant from Nov. 12, 2014, to Sept. 11, 2017.
Dealers will remove the four battery harness clips at the battery tray and one elbow guide, then install a wire channel shield and protective sleeve to the battery cable harness. The Ford reference number for this recall is 19S41.
Safety compliance recall for select 2018-19 Ford F-Series Super Duty vehicles with LED headlamps
Ford Motor Company is issuing a safety compliance recall for select 2018-19 Ford F-Series Super Duty vehicles with LED headlamps. Affected vehicles are equipped with high-series daytime running lamps controlled by an incorrectly configured body control module. When the daytime running lamps are illuminated and the master lighting switch is moved to the low-beam position, the daytime running lamps do not revert to parking lamp intensity as required by federal motor vehicle safety standards.
This action affects 86,296 vehicles in the U.S. and federal territories and 14,079 in Canada.
Affected vehicles were built at Kentucky Truck Plant:
  • 2018 Ford F-Series Super Duty vehicles built from May 1, 2017, to July 13, 2018
  • 2019 Ford F-Series Super Duty vehicles built from March 5, 2018, to Oct. 8, 2019
Dealers will update the body control module. The Ford reference number for this recall is 19C10.
About Ford Motor Company
Ford Motor Company is a global company based in Dearborn, Michigan. The company designs, manufactures, markets and services a full line of Ford cars, trucks, SUVs, electrified vehicles and Lincoln luxury vehicles, provides financial services through Ford Motor Credit Company and is pursuing leadership positions in electrification, autonomous vehicles and mobility solutions. Ford employs approximately 191,000 people worldwide. For more information regarding Ford, its products and Ford Motor Credit Company, please visit corporate.ford.com.
WRCRaptor
Great Lakes
Build date week of 9/16 so I guess I will get to go to the dealer sooner then expected for first service.
Thanks for posting!
K223
Florida
Had anyone gone in for Recall 19S40? It sounds like I could just inspect and clean up the excess sealant myself. But does it take Ford to clear the recall notice on FordPass once it’s been done at the dealer? This is annoying to constantly look at.
WraptorBoy
US
You probably want to go in and have it officially signed off as being repaired. I hate to bring mine in as well but if any issues happen and you haven't taken it in within a reasonable amount of time, it's just more ammo for some dealers to deny warranty.
Let's just hope you get a good caring tech who doesn't make things worse!
FordTechOne
Detroit
Yes; the Field Service Action (FSA)/recall will not be closed out in the Ford database until the dealer submits the claim. You could certainly clean off the sealant yourself and then bring it to the dealer for inspection and to have the FSA closed.
Donmatteo
Santa Clarita / Coronado
Still waiting on parts for this one for the wife’s Lincoln.
We got the letter in dec and then got the parts are available letter. Called the dealer, they picked it up and then said, they need to order the parts and then they dropped it off.
times like this I wish ford had a factory service center and not a dealer service model.
FordTechOne
Detroit
I hate to beat a dead horse, but I must say I agree. Dealership franchises have the market in the palm of their hand; consumers have no other option due to franchise laws and powerful dealer lobbyist groups. There are plenty of good dealers, but they seem to be far and few between. The rest screw over the customer and the manufacturer with the intent of self enrichment. I equate it to working with a 3rd party...the middle man always makes out at the expense of the other 2.
fordfiesta
Mexico
me too There are plenty of good dealers, but they seem to be far and few between. The rest screw over the customer and the manufacturer with the intent of self enrichment. I equate it to working with a 3rd party...the middle man always makes out at the expense of the other 2.
