Changing Factory Fogs to Aux 6
csixer66
Wondering how I can switch the aux for fogs to number 6 spot. Want to run my Baja Designs spots on the first 2 switches as its easier driving on the road having to turn them off and on with traffic.
Also if I wanted to switch the 2nd fogs into running on Headlight switch. Where do I find the Aux one switch wire to switch it to what I want to run?
Littlefx4
For starters, I’d suggest you purchase the harness in the link below to simplify what you’re trying to do…you can read about what it does when you open the link. From there, you can connect whatever lights to whatever switch how you see fit.
As for trying “to switch the 2nd fogs into running on Headlight switch”, the outside set are already connected to the headlight knob (switch as you call it)…just push the center button on the knob. There are some Forscan mods you can do to engage the fogs w/ high beams but don’t think that’s what you’re trying to do.
C
csixer66
I did plan on buying the harness to tie the 2 front fogs together. So I understand all that. Where would I find the Aux 1 switch wire. As the harness for the upfitters only has 5 wires as 1 is accounted for by factory.
Thank you for your help.
Littlefx4
This video will break it down for you. John has a host of videos showcasing his products. You may want to check them out.
Specialtyperformanceparts
Give me a call if you still have questions about this and how to achieve your goals with our plug-and-play harness system.
You can call or text me at (317) 934-6778.
Thanks!
Sidney @ SPV Parts
