GEN 2 Baja Designs S1 Flush Mount Install
OffroadAlliance.com
Boston, MA
@FordRaptorLights.com do they make those flush mount backup cubes with a smoked lens so they would blend into the bumper better?
Most smoked lenses would diminish the light output. Baja Designs does not, but Rigid does have a Midnight series that is darkened and available in a flush mount. Not quite as compact, but still a good option if you're wanting a darker looking light.
WY
cool thanks. I think i saw those are too large to put in the bumper square like the S1 - might just have to go that route.
4x4TruckLEDs.com
You should check out the Baja Designs S1 Flush for sure if you want to mount them into your bumper. We offer one of the best reverse upfitter harnesses on the market with built in protection circuitry so you don't back-feed your stock reverse lights AND it's custom designed to be an all-in-one harness from the upfitters back to your lights (less connections/things to worry about).
You can grab our S1 Flush Mount Reverse Kit Here: http://www.4x4truckleds.com/baja-designs-ford-raptor-2017-s1-flush-mount-reverse-light-kit/
Flash1034
N/W Montana
I like those Rigid Midnight lights. They would look better integrated into the bumper than the white lens lights.
dillard09
College Station, TX and Socal
Decided to install a set in my SVC bumperView attachment 135622
Hey Dustan, so I have the SVC rear bumper and was looking at adding some back up lights. Thats looks just like what I was thinking of doing. Perfect!! You have any closer pics? How mush room do you have over on the license plate side?
Thanks in advance for any tips and tricks.
JohnyPython
Canada
Planning the install of my S1s flush mounts in my rear bumper. I made some templates and thought some of you may need them. Just print the PDF.
  • S1 Template.pdf
JohnyPython
Canada
Templates worked really well. Measured like 50 times to make sure it was right.
Used a ***** punch to locate the hole centres. Then made them bigger with a centre drill.
Hole saw was a little scary but I just took my time. Deburred everything afterwards.
Test fit and looks really good.
