surfnsocal
I installed a pair of flush mounts S1's in the work/scene configuration. Installation was really easy. Took a lot of time positioning them.
One thing that is weird is BD's website says you can install these with a 1" hole saw. However in the directions, it reads 2.5" (accurate).
I decided to wire them to an AUX switch and not tap in to the reverse lights. There are some instances when I don't want them to come on (late night departures in residential neighborhoods, draws attention, etc.).
I'm really happy with how they turned out. The work/scene lens is REALLY bright (I can only imagine the Wide/Corner or Spot). Enough to help with backing up, hooking my trailer up, or running in the desert.
Normal Reverse Lights
BD S1 Work/Scene
BD S1 Work/Scene
