What tires would you run?
burntoutaccountant
seattle
My truck is my daily driver. It only sees light off-roading. I need something that handles good as a dd but can also perform off-road. I was not impressed with the ko2 tires on my wrangler. I have kn3 tires on my bronco but those don’t do well in the rain here in Seattle.
Pacific Wheel
Reno, NV
Falken AT3/W. They do everything really well. The new 35's are 69lbs so a little heavier than BFG but they come with 20/32's tread depth so 5/32's more than BFG which could explain some of the weight. They have full depth sipes if you see any snow.
Pacific Wheel
Reno, NV
Hmm may have to rethink staying ko3 and check out the at3
Since you have a GEN1 I'd probably go with the load range E AT3 but it weighs 70lbs. The light weight load range C has a max PSI of 35. Unless you have a tuner like SCT that lets you adjust the TPMS threshold down to 30 psi. Just my 2 cents
