Upgraded trans cooler from Fordparts
T3amfish
Your mom goes to college
Utah
Was researching good things to upgrade on the Gen1 raptors and came across a post or 2 about the transmission cooler being too small. They call it the “Saudi” cooler. It’s double the size of the stock US cooler and is a direct replacement and fits the stock location with only 1 minor modification to the inlet hose that you just trim off.
Ford part # DL3-7A095-B
The -B signifies the larger cooler, the
-A is our stock cooler.
I picked it up for $91 from Sam Galloway Lincoln Ford. They shipped really fast. See pics
here is a quick vid I found of someone swapping it. There are other longer vids but this is quick and to the point
CoronaRaptor
CANADA
Jeeesh, that looked so damn easy. Yeah, good idea about adding some fluid before you put that top hose on.
MrGable27
High Desert
Dollar for dollar, I’m convinced that this is one of the best mods that you can do to a Gen 1 (especially if you live in a hotter climate). The install took me 30 minutes, and dropped my trans temps 20 degrees while towing an enclosed car trailer.
Anthony k
Michigan
it lowers the temp ZERO!
I drive to my cabin 3 hours away in all weather, towing a trailer every single time. I log temps and fuel.
This cooler didn’t change the temp AT ALL! not one single degree!
I make this trip 2-3x a month.
Exact same route
RC51TOFUMAN
in Thee OC
Exact same route
Thankyou for the update......
I was very tempted to add this to my ToDo list
Sent from my SM-G973U using Tapatalk
B E N
Frederick, CO
Exact same route
What temps are you seeing?
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
Exact same route
i dont think it will necessarily lower temps, but it should regulate it better so you dont overheat as much
HAP
NE NC
Exact same route
I got the same results; seem to make no difference at all. But I do feel better about adding it. Just towed my boat to FL and back as I have done many times. Highest temp was 203 going over a bridge at 77mph. Normal is 195 with or without towing anything, winter or summer.
R,
HAP
