Upgraded cams and headers 72hp and 54 ft lbs
Livernois Motorsports
Michigan
Just finished up this Ruby Red jewel upgraded Livernois Motorsports cams Cold air in take headers and tune. All done and turned around in less than two weeks.
tplee
South Carolina
Dyno report, please.
Sent from my Pixel using Tapatalk
---------- Post added at 08:28 AM ---------- Previous post was at 08:16 AM ----------
Also...how do the current heads flow? Like cams, there are just about zero options out there for the 6.2. I know guys do a custom cam grind, but "one option" is "no options" (i.e. one ends in an 's', the other doesn't). And then, of course, head flow/valve characteristics go hand-in-hand w/ cam lift, duration, overlap, etc, etc...
I guess what I'm asking, why doesn't the Ford 6.2 not get more attention from the aftermarket?
ogdobber
72? That's 483hp son... i like that
tplee
South Carolina
Not really... I doubt they are talking flywheel HP. You are adding what is likely chassis dyno numbers to numbers taken from the flywheel. So, i guess it could reasonably be an even bigger number. But at any rate, would like to see the graph from the dyno.
ogdobber
Oh right. Even better [emoji6]
