GEN 2 Revised SDHQ A Pillar Brackets
dude1782
PHX, AZ/SLO, CA
This truck is running Rigid Dually XLs on the revised SDHQ a pillar brackets that allow you to run bigger lights on the a pillars without interfering with the antenna. I was able to move my lights inward on the old brackets but that only introduced new problems so I will also be getting the revised brackets. You can see pictures of my install on my build thread through the link in my signature.
These brackets require no drilling and it's an easy install for anyone
rms8
You wouldn't happen to have any pics of the brackets and how they attach while you where putting it together, would you?
THX
dude1782
dude1782
PHX, AZ/SLO, CA
Pro tip to anyone installing these bad boys: cover up that hole that goes into the fender with some tape or something, you just might save a socket. If you already lost a socket to the fender, the parts guy at my dealership says there's an easy way to get them out. I'll try that this weekend and I'll get pictures of how to do it and what to cover up.
Sitdown
Suburbia, IL
Amen to the above stmt... Yes jam a rag in there, gotta pop the flares off to get to some of the liner fasteners, but all ears on learning about the easier access :)
I would have sacrificed a socket, sadly I dropped the hook hinge bolt
dude1782
dude1782
PHX, AZ/SLO, CA
You need to take the wheel off so I'm going to do it when my center caps come in hopefully soon. I'll get pics and post up details to try to make it easy.
Sitdown
Suburbia, IL
Sounds good, look forward to seeing. I likely need to get these revised ones, my early ones look pretty wankster with XL brackets offset (wanted to keep my antenna in play)
