Reset Door Passcode
IU89
San Diego
Thank you - Of course I only have one key - one fob so I assume this approach will not work?
HighwaySentinel
︻デ┳═ー - - - - - - -
California
The master code can be found on a sticker attached to a module that is down in the area of the fusebox in the passenger floorboard area. Used this method on my '21
IU89
San Diego
Thank you - I appreciate the info. I was hesitant to pop that off but if its pretty straight forward I may give it a shot. Bummed the dealer wants $200 to do that very same job.
HighwaySentinel
︻デ┳═ー - - - - - - -
California
It was very easy. A prius owner could probably do it. Just sayin..
Oldfart
Your dealer is being a ****. I didn't have the card in my original packet, they pulled it for me when it was in for some minor warranty work for no charge.
IU89
San Diego
I don't own a prius but I took off the flat fuse panel on pax side but do not see the sticker. I will look again
your dealer is wonderful and Kearny Mesa San Diego sucks by comparison.
Service Tech was quite obnoxious about the complexity involved. ‍♂️
HighwaySentinel
︻デ┳═ー - - - - - - -
California
You need to go a couple of steps further in the link that I attached above. The module is behind the panel with the red x on it.
Once you get behind the panel, you will see a black module with the sticker on it. It will be hard to read. I had to take a picture of it with my camera and then zoom in.
IU89
San Diego
does the red X panel just pull out? Pull and pivot? Its a 2020 Raptor so assume I will find it there just don't want to bust anything :)
HighwaySentinel
︻デ┳═ー - - - - - - -
California
Click on this link
Scroll down to "Method 3" and follow the steps
