- Joined
- Jul 15, 2017
- Posts
- 1,084
- Reaction score
- 975
Holiday Sale going on NOW, Store Wide thru Dec 31st. Save on all SPV Kits, Baja Designs, Roush, Morimoto and more. First Responders and Military can check out through the GOVXID link at checkout.
NEW Gen 3 Light kits NOW IN STOCK!!
We have our OEM Fog Upgrades IN STOCK that can hold, Baja S2's, Rigid SRM or Diode Dynamics SSC2's. Pick from virtually any option.
If you're looking for the Baja version of the S2 kit, we have those coming as well, but not only do we have ours NOW, without wait.. But you also have some key advantages with our upgrades. Remember, you still get the same Baja S2, Rigid or Diode Dynamics lights... We just try to give you some additional benefits to how they install, hardware and more light choices within those brands and, most often w give you price advantages. All of our brackets are stainless steel as well.
So check out our chart comparing the OEM housing kits from US and Baja below. For Rigid and Diode, there isn't an option from them. So we have you covered there as well.
We have our Standard Duty A-Pillar mounts IN STOCK now. These work GREAT for the standard size pod lights. Rigid D-Series & SRM, Baja Squadron and S2, Diode Dynamics SSC3 and SSC2. The Brackets are available individually and combined with kits. The kits also include our A-Pillar harnesses from our plug n play system.
We have our LOWER Light Bar Brackets and kits IN STOCK now as well. These lower brackets will hold several lights from Baja, Rigid or Diode Dynamics in 6", 10" or 12" lengths.
We also have our Rear kits in stock with Baja S2 Sport OR Pro, Rigid SRL, Radiance, Scene or D-Series Flood, and Diode Dynamics SSC2's. Our kits have some KILLER advantages with our Patent Pending Harness system and plug n play tail light adapters for reverse trigger... or full harness to switches... or both. SRL, Radiance and Diode SSC2's add the advantage of a red backlight that can tie into your tail light circuit with our tail light adapter.
If you're looking for the Baja version of the S2 kit, we have those as well, but you also have some key advantages with our upgrades. Remember, you still get the same Baja S2, Rigid or Diode Dynamics lights... We just try to give you some additional benefits to how they install, hardware and more light choices within those brands and, most often w give you price advantages. All of our brackets are stainless steel as well.
Of Course we have 2 other Brackets coming (Next Week hopefully!) Our Heavy Duty A-Pillar Mounts (Which many have on reserve, which will ship right away) and our HIGHLY anticipated Triple Fog Mounts for the Gen 3. You can still preorder BOTH now.
Our Triple Mounts allow you to install 2 or 3 pairs of: Rigid D-Series, Radiance/Scene, Baja Designs Squadrons (Sport/Pro/Racer), S2's and S1's, or Diode Dynamics SSC3 or SSC2 lights (Sport or Pro)
A Clear advantage to our kits vs the Baja branded kit (If you're leaning toward Baja Lights, is the fact that you can get 3 FULL SIZE Squadrons in there, vs 2 and an S1. The other advantage is, even with 3 full size, your cost is still a little less with our full kit, and you also have some improved wiring options. Last, you can mix and match virtually any light. Remember, these are the SAME Baja lights. Check out the chart below to see how the SPV kit compares with the 4 Baja kits. When it comes to Rigid and Diode, you're getting the best kit with the best lights because there isn't a kit to compare with theirs. We also made ours as easy as ever to install. So you have many slots and adjustments. That's great. The problem with MANY other companies that make universal mounts is, they just randomly throw slots in. We actually use specific lights and fitment when designing our mounting locations. So everything has the best look and fit. We also include a template marked with each location for Baja, Diode and Rigid. So not only can you line them up perfect in the slots. You can also align them STRAIGHT FORWARD all at once! No moving around doing minor adjustments. NO ONE has ever produced a kit that will be as easy to set up and install. This will take out your guess work. Of course, you still have the freedom to move them wherever YOU want.) (Also for the Baja customers, these ship in a week or so, not several weeks out.)
Check out the compare chart below..
Then our Heavy Duty A-Pillar Mounts (Don't forget to add lights and the A-Pillar Harnesses! There were just too many options to bundle!) Pick XL Lights, Normal lights.. LP6, etc. These are made from 7 Gauge Stainless Steel.
Happy Holidays! and we look forward to serving YOU!
Be sure to send us emails, call, text or send us a PM for any questions you may have. That's what we are here for!
John
SPV Parts
SPV Parts 2021-2024 Ford F-150 & Bronco Raptor OEM Fog Light Upgrade Kit with Brackets and Baja Designs S2 Lights
New SAE Models Available! (In Stock NOW!) If you own a 2021 and up Ford F-150 OR Bronco Raptor and you were excited about the included Rigid Fog kit, but were disappointed with the performance, you are not alone. Rigid makes some of the BEST lights out there, but Ford unfortunately took the...
specialtyperformanceparts.com
SPV Parts 2021-2024 Ford F-150 Raptor & Bronco Raptor OEM Fog Light Upgrade Kit with Brackets & Rigid SR-M Direct Replacement Lights
NEW MODEL!! If you own a 2021 up Ford F-150 OR Bronco Raptor and you were excited about the included Rigid Fog kit, but were disappointed with the performance, you are not alone. Rigid makes some of the BEST lights out there, but Ford unfortunately took the cheap path and only included some of...
SPV Parts 2021-2024 Ford F-150 & Bronco Raptor OEM Fog Light Upgrade Kit with Brackets and Diode Dynamics SSC2 Lights
Purchase a flog light upgrade kit for your 2021+ Ford Raptor online! This OEM upgrade kit includes mounting brackets and Diode Dynamics SSC2 lights.
SPV Parts 2021-2023 Ford F-150 & Bronco Raptor Fog BRACKET OEM Adapter Kit (Brackets ONLY. Lights sold separately)
Key Highlights include- All stainless steel design for superior corrosion resistance. Full Black powdercoat for both corrosion & optimal appearance. Allows adaption and replacement of the stock Rigid DOT lights Will allow mounting of Baja Designs S2, Rigid High Power SRM or Diode Dynamics SSC2...
SPV Parts Rigid Standard A - Pillar (Ditch) Light Kits for Ford 2021+ Raptor/F-150
Purchase our a-pillar light kit for your 2021+ Ford Raptor or F-150 online at Specialty Performance Parts! This kit includes a custom wire harness and brackets.
SPV Parts 2021-2023 Ford F-150 Raptor/ F-150 Standard Duty A - Pillar (Ditch) Mounts (Fits most 3" Light pods)
These SPV A-Pillar Mounts will hold any 3x3 size Pod light by Rigid, Baja Designs, Diode Dynamics and many others. The larger hole accommodates all bolt sizes. Stainless steel and black textured powder coat. Fits 2021+ Raptor and F-150 (Lights sold separately)
SPV Parts 2021-2023 Ford F-150 Raptor 10'' LOWER Grille w/Rigid Industries Light Bar Kit (Behind Grille)
The NEW Behind the LOWER Grille Light bar Kit by SPV Parts allows you to install a 6" or a 10" Rigid Industries LED Light bar in the lower grille opening of a 2021+ Ford Raptor. There is a wide array of options in choosing the combination you want. These light bar options come in either the "Pro...
SPV Parts 2021-2023 Ford F-150 Raptor 10'' LOWER Grille w/Baja Designs S8 Light Bar Kit (Behind Grille)
The NEW Behind the LOWER Grille Light bar Kit by SPV Parts allows you to install a 6", 10" or 12" Light bar in the lower grille opening of a 2021+ Ford Raptor. There is a wide array of options in choosing the combination you want. This kit includes your choice of Baja Designs 10" S8 Light Bars...
SPV Parts 2021-2022 Ford F-150 Raptor 12'' LOWER Grille w/Diode Dynamics Light Bar Kit (Behind Grille)
The NEW Behind the LOWER Grille Light bar Kit by SPV Parts allows you to install a 6" or a 12" Diode Dynamics LED Light bar in the lower grille opening of a 2021+ Ford Raptor. There is a wide array of options in choosing the combination you want. NOTE: If you live in a state that REQUIRES a...
SPV Parts 2021-2022 Ford F-150 Raptor 6''-12'' LOWER Grille Light Bar BRACKETS
The NEW Behind the LOWER Grille Light bar Brackets by SPV Parts allows you to install a 6" or a 10" or 12" Rigid Industries SR series Light bar, Baja Designs S8 Light bar, or Diode Dynamics Light bar in the lower grille opening of a 21+ Raptor. (May work with other brands as well) NOTE: If you...
SPV Parts 2021-2024 FORD RAPTOR REAR Rigid SR-L SERIES REVERSE LIGHT KIT (NO DRILL) SRL rear light kit
Purchase a new reverse light kit for your 2021 Ford Raptor online! This rear light kit comes with mounting hardware and installation instructions included.
SPV Parts 2021-2024 Ford F-150 Raptor RED Rigid Radiance or Scene Reverse Kit
Purchase a new Rigid light for your 2021 Ford Raptor online at Specialty Performance Parts! You can choose either standard radiance or scene lights.
SPV Parts 2021-2024 FORD RAPTOR - REAR BAJA DESIGNS S2 / SPV REVERSE LIGHT KIT (NO DRILL/MOD) rear light kit
Purchase our new rear light kit for your 2021 Ford Raptor online! This kit features Baja Designs S2 lights that can be configured in several ways.
SPV Parts 2021-2024 Ford F-150 Raptor Rear Diode Dynamics SS2 Series Reverse Light Kit (No Drill) Red Backlight Rear LED
NEW! The new SPV Raptor Reverse Light kit utilizing the Diode Dynamics SSC2 Series lights are here!! Similar to the Radiance series, these DD new lights have a Red backlight when off and a powerful white backup light when on. The advantage to these is the slimmer case with a 2 series led. If...
SPV Parts 2021-2024 Ford Raptor Rear Rigid Pro Light Backup Kit w/ Rigid Industries #202113 Flood Lights
Specialty Performance Parts EXCLUSIVE 2017-2020 Raptor backup kit is ready for your Raptor! This kit uses 2 Rigid D-Series flood lights for maximum coverage and illumination behind your truck! Don't sit in the dark! Pick yours up today and join the SPV family!
SPV Parts 2021-2024 Ford F-150 Raptor Gen 3 Rigid Industries D-Series PRO Triple Fog Light KIT
Ford Raptor Fog Cube Brackets for 2021-2022 Raptor in STAINLESS & BLACK POWDERCOAT The NEW 2021-2023 SPV Parts POD light fog brackets are HERE! This is the first, and we think will stay the BEST for quality, fitment and adjustability! We hold our quality standards very high! Please keep in mind...
SPV Parts 2021-2024 Ford Raptor Baja Designs Sport & PRO Triple Fog Light Kit (With Brackets)
Customize your Raptor with an SPV Pro Fog Light kit! This kit includes a pre-configured Baja Designs pro or sport light selection, and our custom SPV fog brackets that we specially designed that offer more adjustability than ANY other fog brackets on the market! This kit is sure to give your...
SPV Parts 2021-2024 Ford Raptor Diode Dynamics Sport & PRO Triple Fog Light Kit (With Brackets & Harness)
Customize your Raptor with an SPV Pro Fog Light kit! This kit includes a pre-configured Diode Dynamics pro or sport light selection, and our custom SPV fog brackets that we specially designed that offer more adjustability than ANY other fog brackets on the market! This kit is sure to give your...
SPECIAL BUY - SPV Parts 2021-2024 Raptor - Rigid Radiance/Scene Fog Light Kit w/amber backlight - Including Brackets/Harness
Ford Raptor Fog kit including Brackets and triple harness for 2021-2022 Raptor in STAINLESS & BLACK POWDERCOAT The NEW 2021-2022 SPV Parts POD light fog brackets are HERE! This is the first, and we think will stay the BEST for quality, fitment and adjustability! We hold our quality standards...
SPV Parts PREMIUM 2021-2023 Gen 3 Raptor Triple Fog BRACKETS (Brackets ONLY. Lights sold separately)
Ford Raptor Fog Cube Brackets for 2021-2023 Raptor in STAINLESS & BLACK POWDERCOAT The NEW 2021-2023 SPV Parts POD light fog brackets are HERE! This is the first, and we think will stay the BEST for quality, fitment and adjustability! We hold our quality standards very high! These are the newest...
SPV Parts HEAVY DUTY 2021+ Raptor/ F-150 A - Pillar (Ditch) Mounts (Fits most 3" Light pods and BIGGER)
These SPV A-Pillar Mounts will hold MANY Pod lights by Rigid, Baja Designs, Diode Dynamics and many others. This heavy duty, one piece design allows you to quickly and easily bolt in the bracket without even removing the cowl. Unlike our standard duty bracket, and many other brackets available...
Individual LED POD Lights
We offer the best LED light pods selection for your truck. Browse our Rigid Industries LED pod lights for the Radiance, Pro, & Amber off road lights series today.
Harnesses and Connectors (All Makes/Models)
SPV's Ford Harnesses and Connectors offers an impressive selection of light bar wiring harnesses, fog harnesses, & other wiring kits to improve your Ford truck.
John
SPV Parts
