My Roush SC Install
HAP
HAP
NE NC
Side mirror turn signal strips......where did you get that?
Sent from my SM-G920V using Tapatalk
There was a member on here that made a handful of these as an experiment; I just happened to get one. They are back lit but I never hooked the wire up. Not crazy about how they looked illuminated...
R,
HAP
Squid 3
Ipswich, MA
Yea I saw that. That's why I was asking about part numbers. My filter doesn't look like that one
# 997-466 is the replacement part number.
Don't freak out that it's MUCH smaller than the original because it is
I just wen't through this with Roush and they assured me that this is right
Geldingmakr
WV
That filter is dry and you should be cleaning and oiling more often.
I bought a second filter so I can clean and oil one while the other one is in the truck.
Thanks, I have a lot to learn apparently I should look in to relocating my Fuse 27 and a JDM tune as well
MTF
Celebration, Florida
The fuse thing is a good idea, at least change the fuse to a mini instead of the micro.
I didn't do the relocation, but I did change the fuse way back in 2012.
The micro fuse blades are not wide enough, and that makes the connection at the edge of the blades creating a hot spot.
