Feedback on RPG 2.25" collar
dasbury
SW Florida
I'm a numbers guy, so i get it. Measurements don't lie - something i did notice though is the optical illusion. On white, AG, light colors, the optics change dramatically once you coat / paint the inner wheels wells. the back appears to sit much higher with all of that "white space". My point is - is it the math you're going for, or the look? i'm not suggesting either is correct. While my 1.5" RPGs work for me, there was still slight rake. Now that I have towed for about 1500 miles - the truck sits very close to level. Anyway, food for thought - optics, measurements, and rear settling.
Cheers,
Dennis
hamster
Northern VA
Cheers,
Dennis
Agree completely.....the optics were that the back end was sky high until I coated the wheel wells. Then added the 1.5" collars. Still has a very little rake, but that is what I prefer. Very pleased with final result.
Jayrod
FL
What coating did you go with?
X
xxaarraa
Southlake, TX
Thanks for posting the pic, that's very helpful.
Maybe I am the odd one out compared to all you guys, but looking at that photo, it seems to me that you are slightly nose high. Not sure how you guys perceive rake.
I think my towing has made my back end settle quite a bit. I don't mind it at all. I just wish my front end wasn't as squishy, but I think that may just be the nature of the beast so I am likely to just leave it alone and enjoy the truck.
hamster
Northern VA
Seems everyone measures different. What I prefer are two things. 1. Gap between tire and fender on front tire same or less than gap on rear tire. I am little less in front. 2. On level surface, the bed is level or slightly lower on front. I used a 4' level to check. I am not all that worried about 1/4" here or there.....it just had to look good to me and it does....so I am good with 1.5" collar in front.
Jayrod
FL
I remeasured today and I'm now within an inch. It did move some as it was stated earlier. I will leave it be. Close enough.
X
xxaarraa
Southlake, TX
I backed off the 2.25 and finally got around to getting the RPG 1.5" collars installed. I am happy with the results - truck is 100% level, if not slightly, very slightly even higher in the nose. Have to get it re-aligned soon.
Thanks for all your thoughts and feedback, including pics.
