Catch Can Questions
MurderedOutSVT
Brodozin
The ATL
After much searching around, best I can find is equal arguments for Moroso and JLM.
Sooooo....I need some direction.
Better kit opinions? Do Both come with mounts? Seen alot of debate on one of the kits hitting the coil pack/coil pack bolt
Running a Procharger DS-1, does that make a need for 2? If not, which side should I put it on?
Ruger
Northern Nevada
I bought the Moroso catch can. It comes with a mount, hoses, and everything you will need to install.
Installation isn't even a one-beer job - anyone could do it.
I have been running it for years now. No issues. Works like a charm. Completely satisfied.
MurderedOutSVT
MurderedOutSVT
Brodozin
The ATL
Moroso with the clear can.
You only need one on the passenger side.
The driver's side is for fresh air intake.
Thank you very much!
pat247
Oklahoma
I started with the JLT catch can then after a few years switched to the Moroso and been running it for a few years. In my opinion they are both quality products, the Moroso catches twice as much oil in the same time frame and Moroso offers the clear cup for easy checking oil level.
SJC8713
NorCal
I have the JLT and install was a breeze, the moroso sounds nice just to visually check the levels easier because of the clear cup.
Dont think you can go wrong with either.
KOBRA2848
I ended up going with a Bob’s Oil Separator on my 2014 since that is what I put on my Shelby in 2012. I like that it is super easy to drain with the drain valve on the bottom and it catches about a 1/4 cup every oil change. The main reason I chose this one is that the factory PVC hose is 5/8” which is the same as Bob’s whereas most of the others have 1/2” hoses.
Mark
lkmcfee
British Columbia, Canada
I have the JLT catch cans, they came with all the mounting hardware and have worked great. I check it every 3 months and there is 3/4 of the container full each time.
