Camber / Caster Kit, Specialty Products Company p/n 86250
Specialty Products Company p/n 86250: Yes or No? Muti-Choice!
  • Total voters
    24
Badrap
Haslet, Texas
Don't waste your money. A few off road trips and they still kick out of alignment. And yes they were torqued up right.
PropDr
Eugene, Oregon
You cannot get proper torque on the but with this kit. It forces you to torque the bolt instead of the nut. That's why everyone's moved around at havoc
Sent from my iPhone using Tapatalk - now Free
This is, from an engineering point of view, a ignorant statement!
JMEPOV (Just my engineering point of view)
---------- Post added at 09:21 PM ---------- Previous post was at 09:01 PM ----------
The problem is that installers/adjusters don't pay attention!
If you don't properly loosen the bolt prior to rotating the cam with the nut you angle the bolt.
The bolt needs to be perpendicular to the adjustment *****.
1stSFG
The Mountains
The instructions say to torque the cam bolt to 240-260 lb-ft. and "make sure the suspension is loaded before tightening". It may be a good idea to unload and load the suspension several times after the alignment, then re-torque the cam bolts.
I understand that you normally torque the nut. Maybe, this kit would be better, if the offset washer were on the bolt and not the nut?
This should be understood to be essential to,"Reset",the suspension. If it isn't done you have a potential dangerous and damaging "preload" on the suspension.
I learned this the hard way on my camaro. I launched off a joint on the interstate on an overpass and almost caught air. It sent my head into the roof and the tires barked when it sat down. Great catch Joker.
Huck
Chicago Sw Burbs
This is coming from an engineer. By torquing the bolt you have other factors loading the bolt, weight or the vehicle, or if on a lift, the force from the suspension all that effects the torque being applied
TheJoker
TheJoker
N. E. Massachusetts
How were everyone marking the bolts to see if u went out of align? Any pics?
Because I haven't had the alignment done yet, I don't have any pics. I will post some as soon as I can. Basically, you simply draw a straight line from the offset washer across shoulder plate. Similar to how you would mark bolts... ok here are some ****** pics:
I have a paint pen, which would last a long time. Then, you could remove the line before your next alignment. Then put a new one on after the alignment is complete. Hope this helps.
AZEngineer
Phoenix AZ Area
I still haven't had time to Install the RPG front Fox coilovers. I bought two of the alignment kits to install at the same time based on what I thought was the consensus of the forum.
Should I bother putting the kits on?
