Burger Motorsports
TurboM
Johns Creek, GA
Not sure about the Ford world but with BMWs these types of piggybacks can be detected but not easily and in a completely different fashion than the way one would detect a flash tune. Basically, other sensors not manipulated by the piggyback would likely be showing values outside of their normal operating thresholds which would certainly raise a red flag if someone dug into the log files. I will say this is pretty rare though and the only reason BMW/Ford would dig into this would be a very expensive repair such as catastrophic engine failure.
Syberspace
Pittsburgh
I ran this on my 2008 BMW 335i. Great piggyback and really woke up the car.
Never had any issues with it.
K223
Florida
They will wake up a Raptor too. Normal mode is improved but at times still laggy. Sport mode is a treat! The truck can really use a TCM tune but this works good.
JCU Delt Ox
Ohio
I got the JB4 installed without issue. The toughest part of the whole install is running the cable through the firewall to the OBD. I'm running Map2 because I run 93 Octane at all times and the truck is running great. The JB4 App that costs an additional $27 isn't functioning as well. It connects fine, but many of the gauges show no reading. I need to play around with the App more to figure out what's going on.
K223
Florida
You purchased and configured the BT adapter correctly?
JCU Delt Ox
Ohio
No issues with the install. It syncs up to the truck just fine. The problem is the read-out on the App is hit and miss. Sometimes i'll be connected and see all the gauges and another time the only reading displayed is boost. I'm going to keep monitoring it.
K223
Florida
I’d make sure everything is updated.
