Brad's 2014 SCREW
Brad12
Brad12
Bay Area
Finally got my 37x13.50x17 Gladiator XComp ATs mounted on the new Icon Rebound Pros 17x8.5 6mm offset in Titanium. They match pretty closely with the gunmetal fender flares which I like. The clearances are tight and the driver's side is rubbing just before full lock, but I put in a few hours of fairly hard offroading and they didn't rub on compression... I haven't jumped it yet however.
Brad12
Brad12
Bay Area
Sent the shocks off to Icon to be rebuilt and took the opportunity to clean up the frame a little bit (what looks like dirt was actually paint!), install properly shanked bolts in the rear lower/upper shock mounts, and install new rotors and pads in the front. The rear diff was also seeping, so I replaced the fluid and re-sealed it. Getting the rear lower shocks mounted was a bit difficult due to the amount of droop in the Icon kit and not releasing the nitrogen, but I eventually got it by jacking up the rear of the truck by the bumper and using another jack to compress the shock... it was a little bit sketchy :cool:
Old bolt on top. New, properly shanked bolt on the bottom FTW!
Everything back together on the passenger side. The mount for the degas bottle makes it a little challenging to route the external reservoir through the top and toward the front for mounting.
Rear diff...
