GEN 2 3” Geisers & Icons Option 3
screaminfast
screaminfast
Rochester NY
Also curious as to what old measurements were. I am running Icon collars also and feel like the front end might have a bit more height to it, but I don't want to run severe angles on the CVs.
I didn’t measure beforehand but my collars were set to the 1.5” and I’d say I gained about another 1.5” up front and a full 3-4” in the back
screaminfast
screaminfast
Rochester NY
Just measured again:
FL: 41
FR: 41.5
RL: 43.75
RR: 44.5
The parking lot I just stopped at probably isn’t perfectly level so it seems like both front and rear have settled about an inch. A spacer plate might give it just enough in the front to take out some of the rake as I don’t want to do drop shackles and lose clearance.
screaminfast
screaminfast
Rochester NY
Just spoke to SDI and they don't recommend using their bucket because it'll create "too much rebound for the stock components." So I'm back to thinking about just making a 3/8-1/2" plate spacer to go above the hat to give the front just a tad bit more height.
BoostCreep
SoCal
Why do you need so much ride height? If you want the lifted truck look you could use the 4” fabtech kit if that’s what you’re after.
screaminfast
screaminfast
Rochester NY
I certainly don’t need it. I do like the way the truck looks now. Like I said above. Maybe a 3/8” plate would be enough above the hat. 37’s in the spring. I’m sure I’ll be happy.
