Zombiekiller's "Donkey" build up
Jakenbake
negative.
My truck is staying leaf springs. I plan to start building another truck in a year or so that will be J arms and links. ( and no, I have no intention of selling my raptor when I build the new truck).
I was actually referring to keeping the back half as you currently have it, but with the exception of tying the top hoop of the interior cage to your bed rack/frame rails for some additional stiffness. Though I guess that may not be necessary?
Either way, enjoying the build!
zombiekiller
zombiekiller
OG BooBooRunner
New Orleans
the only reason i'd need to tie the two together would be for triangulation if I were linking the back of the truck. ( upper coilover and shock mount triagulation) Else- not much reason to do it.
I also will retain the ability to completely remove the bedcage, even if it is a bit of a chore. ( the bed cage is tied into a bunch of different things, including the rear bumper, so removing it takes a bunch of work and either 3-4 people, or a forklift.)
Dozer466
TX
Are you going to 40 spline axles with the 10” or sticking with 35?
zombiekiller
zombiekiller
OG BooBooRunner
New Orleans
I'm running the competition 35 spline ARB and 300m 35 spline axles.
Going to a 40 spline ARB would require going to a 3.812" case.
it would also mean having to get custom front spindles made, change out the alcon brakes, new wheels, and change out the rear hubs, as no one makes a 40 spline 6x135 set of rear hubs.
and if I were to go through changing out all of that, I'd honestly go to 36 spline TT bolt pattern and a spool.
going to 40 spline would run me somewhere around $18K-$20K. Not really interested in spending that .
K223
Florida
Have you ever broke a 35 spline axle? High end 35’s are pretty rugged.
zombiekiller
zombiekiller
OG BooBooRunner
New Orleans
I have not, which is another reason that bumping up to 40 spline or 36 spline doesn't really make sense to me at the moment.
I'll most likely buy a set of spare axles, a spare hub, and set up a spare third member with a spool. Once I buy them, I have no doubt that they'll all sit in the chase truck perpetually.
K223
Florida
Pretty much what I was getting at. But I wasn’t sure if you had any previous breakage to force you to upgrade. Your plan makes sense.
Dozer466
TX
10:4, I was just curious. I also just re-geared and stuck with a 9” ring gear and kept the 35 splines. Awesome build by the way!!!
zombiekiller
zombiekiller
OG BooBooRunner
New Orleans
Started getting some parts in, so it's time to clean first. ( polished 5.14s, bearings, LP6s on the way, new wheels ( finally going beadlocks, fresh set of tires, Larger Lowrance, and a few other odds and ends)
If I'm being honest, this year, with covid and all, I hadn't really done much to clean my truck beyond spraying it off with a power washer....once.
So, for the past few days, I've been hitting the truck with a foam cannon and powerwasher, plus scrubbing it down a few times as I prepare to start fixing/changing things.
but, because I was lazy, I'm going to have to disassemble some of the truck to scrape and paint it again.
I get asked a lot "how much travel?"
well, here's a pic of the "cleaning pose". there is about another 1.5" of droop left in the truck beyond where it sits in the pic.
She's gonna have a bold new livery for next year, as I'm gonna turn my dude PGNOLA loose with the wrap. Truck goes to spend time at his shop in Feb, just before I head to Baja again.
