But will it blend?
That website makes me shed a tear. When they blended the Ipad I almost shat.
But will it blend?
Yes you can run EFI one of two ways. I'm about 90% positive Edelbrock sells an EFI manifold for the 460 but the problem is our ECU are to advanced to run something like the 460 when the last one in production was in the mid 90s in the F-Series Super Duty. So you would have to run either Accel DFI or a Megasquirt ECU. The other choice is a little easier. Use a system similar to the FAST EZ-EFI system. Its a self tuning system and can be used on any intake that use a Holley 4bbl carb.MagicMtnDan said:I suspect the first concern with that motor would be its size and weight (and it doesn't have EFI, etc.).
Tim's already suggested perhaps the best solution: the 5.4 blown GT500 motor. The new one weighs 100 lbs. less than the one in his GT500 so it's even more attractive thanks to the weight savings and it puts out 545HP (IIRC).
Really C-cast heads would be the best bet. C-cast heads are what come on 99/01 Cobra, 03/04 Mach 1 and te Terminator. They have several updates from the R-cast heads(FGT/GT500/00R). Intake Manifold for C-cast heads are easy to get unlike 00R manifold where there are only 300 ever made.SVORay said:How about a Modded N/A DOHC 5.4 from something like a Navigator/Cobra R? The Cobra R is/was rated at 380hp & 385ft tq
One was SVTP a few weeks ago and te guy wanted almost $2K for it. I really want to see what a 358CID high compression FGT blocked 3v will do. These stroker Mustangs are making some awesome power with 3v heads.The N/A 5.4L Cobra Motor (NOT the GT500 engine) also has an unobtanium intake manifold.
Thanks for the prices. So what's the price of the GT500 motor (I think Tim mentioned it in a different thread)?
How well do supercharged engines hold up off road? This is all far away thinking, after warranty stuff.
Dont superchargers require certain air filters that might let dirt in? They also need intercoolers, runnning in the desert gets a engine hot especially in sand where its running high rpm and not going that fast. I think NA engines are more cut out for a off roader that also has to be a reliable, streetable daily driver. The big block crate motor is less than 10k, much less than the gt500I would venture to guess high speed onroad track use would be a lot more grueling than off road (however could be offset by low speed <read less air thru radiator> Hi rpm offroad use), but I do not have any experience with any supercharged off road applications.
Some minuses are more complicated underhood, potential heat soak issues, hi octane requirement, potential other component breakage (axles, etc)
