GEN 2 Would Fordprotect cover this headlight?
JC2458
Canyon Lake, Texas
I have no idea what is happening on this headlight but it appears to be spiderwebbing and speckling- the damage is extensive across the entire lens. Would fordprotect cover replacement? I dont think any external force or impact caused this. If not, what am I looking at out of pocket? Looks like at least $850 for the entire assembly plus $150-$200 in labor unless I do it myself.
2020FordRaptor
Nevada
It looks like external damage to me. I guess it is worth a try but wouldn’t be surprised if they don’t cover it.
JC2458
JC2458
Canyon Lake, Texas
I actually looked at it again and it is happening on both sides… I will try to get it covered under the ESP… If not, I might consider replacing both and maybe get some nicer aftermarket ones? Those Morimoto ones look really nice
Aftermarket ones don’t last. Better off trying to source a used/salvage pair.
downforce137
In Diana
Don't be so sure. The Morimoto lights seem better quality than the OEM.
well im on my 3rd set of the morimoto marker lights, but the set of 7 lights is $20 more than one OEM marker light that seems to fail at the same rate..
however, i bought them once, and theyve warrantied 2 sets for me..
not sure the quality is quite at the OEM levels, and I have no experience with their headlights but the warranty is much better than Fords..
even with the 12/12k Ford OEM parts warranty (that the dealer had replaced under bumper to bumper, they wouldnt cover the front ones that had water intrusion and stopped lighting up after about 7months ..
Hagasan41
Florida
Looks like your lights are peppered from normal highway driving. Hard to tell from your photos but the issues could be impact related or the crappy polycarbonate lenses. I’ve seen this on several different automotive brans. The crazing is either the lens material failing or in the clear coat. Heat and UV rays are significant factors that contribute to the degrading.
Once you get new lights it may be worth refinishing these by sanding the surface and re coating.
Anyone that’s had the lights out know where they’re made?
