Well I got the outlet wired up today. Getting it through the frame was an adventure.
Looks great! Did you get a slide also? The how did you get through the frame? I used a fish tape and it took me about an 30 minutes or so.
I’ll be using it in AZ for Tuesday to Friday commuting trips, specifically Phoenix all summer where the temp inside the truck or under a bed cover can exceed 140 degrees. The truck will get driven daily, but sometimes not more than 10 miles. I generally keep the fridge full, adding more water to it as I deplete the food. The current dual battery setup in my car works awesome.
Yes I got a slide for it as well. I would hate having to unroll the cover every time I need to get in it.
As for the wiring, I just used my fingers and ran the wire from hole to hole a little at a time. I probably have 2 hours total in the install.
How do you have your duel battery set up? Is the second battery hooked up to the main battery also?
Hole to hole?!?! Damn! Yeah I bet that was a bitch lol. Post some pics!
