Sorry if I confused anybody, I was wondering about the amp draw with the control pendant...I was getting confused thinking that's what the pendant draws..when it's literally just a switch.
Winch will be directly wired to the battery, I am running a serate cable to my onboard switches, there is nothing stating what the control pendant draws, which is why I called...
And extra control pendant only costs 50 bucks..and they easily come apart with a few screws..so I can remove the cable safely from the pendant, rewire each positive (either out or in) to either switch 1 or 2...and connect the ground to the truck..the cable is 3 prong and looking at the controllers function is pretty simple to do.
If I have time in the next 2 weeks I will post a tutorial.
I will really like this entire system, cost effective and removable. I can simply disconnect 2 cables and remove a pin, and winch is gone. And install I can either use my onboard switches or plug in my remote for outside functions..
Switch 3 and 4 will be for my lights.
