Why so many leaks @ 40k miles?
ALRaptor
Alabama
So it appears that I have a leak from the passenger side seal on my front axle, but why is it grease and not gear oil? I also have a leak between my transfer case and transmission. It’s leaking enough to leave drips on the driveway. Does the trans have an output seal? Are these areas prone to leaks with such low milage?
pcs
milky way
that first leak is dried up axle fluid. easy and inexpensive repair. i just changed that seal this past weekend. seal was in stock at a local auto parts. the 2nd not sure, is the oil coming from above the exhaust hanger?
