SCelebs
I'm seeing a lot of people ordering the low profile cut out and i'm wondering whats making them order that vs the standard y pipe version? The y pipe should flow a lot better, at least I would think so. Properly mounted low profiles are fine if they are mounted in a bend where it allows exhaust to flow out easily but side mounting it is going to release less exhaust and will still be flowing quite a bit out of the muffler even with the pressure difference. It may also sound different as a lot of the gases are just flowing past the new found hole in the side of the exhaust.
Would love to hear everyones thoughts on this, if its a ground clearance issue, there is not problem with that if you mount the y pipe correctly. Maybe i'm just missing something here though so speak up
Jeff
Jeff
