I'm running Icon 2.25 kit with Icon 17*8.5 6mm offset and 5" backspace wheels. Toyo Rt 37*12.50*17 tires. Deaver +2 in rear. Had to trim inside front fender well with box cutter (plastic only). I rub slightly on hard right turn only.
Trimmed front fender wells...rub slightly
37" malldozer sawzall modCut the plastic...a little
f'n malldozers![]()
Curious for folks that trim to run 37’s & off-road hard, I mean some rough stuff do you not rub & crack fenders?
Is trimmin' more to prevent rub when sendin' it into Starbucks?
tks for sharingI assume most run 37's for looks...even stock tires/wheels rub the rear wheel wells under compression.
Just built a wicked f'n deck.You're the worst fabricator of all time.
I think your biggest issue will be in the rear to be honest. With those wheels and 37s you will grab the rear plastic outer fender liners when bottomed out. I have seen people rip those off over whoops
ultra impressiveLots of trimmin'...remade fender liners to look factory.
Curious for the folks that do slight trimming and run 37’s and off-road hard, I mean some rough stuff do you not rub and crack fenders?
I know this is about GEN2’s but with my GEN1 on 35’s, I rub the liners good when off-roading. Even though a GEN1 could run 37’s with trimming too, if you wanted to do some serious off-roading, you have to replace your fenders with +2’s or bigger, do the pinch welds and cut the bottom.
So is the trimming everyone is doing more or less for street use and preventing rubbing when turning?
