Decided to knock out a couple quick easy projects this weekend including installing the BuiltRight dash mount in my '17 802a Screw. Incredibly easy install- pulled out the tray with the center speaker, drilled a couple holes and set the mount. Hardest part was mounting the Ram Mount 1" balls to the BuiltRight.
Before I reinstalled the tray with it's new mounts, I decided to fix an issue that's been driving me nuts and wire the usb charger for my phone up behind the dash to the center tray where the mount now is.
To do this, I ended up pulling the screen, radio, center dash panel, console dash panel, and left center dash panel... way more than I expected to get into on "quick easy project day." Wasn't a difficult job, but I probably would have laid off the craft beers if I thought I would be getting into pulling this many panels!
I drilled the holes and routed the cables (phone charger and a USB Hub to power anything I put on the BuiltRight in the future).
Figured I would ask you guys: while I have the dash apart, are there any other upgrades I should consider doing before I put it back together? I have been watching @BIGDJE and @Guy install the Pheonix Android screen and that may be an option in the future. Aside from that, what else could I consider?
