Which ACC bracket and why? SVC / ADD / Bajamod
Booth9999
Idyllwild
oem location isn't centered, its to one side
Agreed but the errors I’m having seem to be picking everything up that is on the right as a eminent collision, maybe it needs to be on the driver side then? Hopefully in the next few weeks I’ll be able to Install my new radiator and bumper then remount the bracket and test it. How much did your body shop charge for calibration and where do you currently have it mounted?
rayofsi
NYC
i have the cobb bracket currently i believe. When body shop did it it was perfect. then ford dealer did some work and messed it up. Probably needs to be recalibrated
i have the add bracket i might install. its more centered for the truck
bad thing about these aftermarket brackets is that it is very hard to center and level it
MAMiller44
MAMiller44
Tampa, FL
So it turns out the SVC IC comes with the ACC bracket which is positioned to be able to use the factory wiring and is adjustable. Just knowing that SVC truly makes some of the best products out there, I’m going to trust them and use their bracket.
Staff online
96,928
60,866
Vulky
