Where to buy replacement oem shocks
EricM
OHIO
What is the part numbers for SuperCrew Cab Front and Rear. I saw where the OP bought them on RockAuto but damned if I can find them.
There are two part numbers you can search for. There are numbers starting with BL3Z- which is a Ford part number. There are also ASH- numbers too, which are Motorcraft numbers.
I have this for the front on a 13 Screw
BL3Z-18124-J
ASH-12263
Rear
BL3Z-18125-K
ASH-24542
Fronts are in stock everywhere- I don't see rears in stock anywhere.
Edit: Rockauto has them too. Fronts are called struts, back are shocks. Probably why you whiffed on the search.
bubblehead93
Charleston
Rockauto... ordered these on September 13th... had them in hand September 21st... they come and go on backorder periodically...
Part NumberPart TypePrice EACore EAQuantityTotal
2011 FORD F-150 6.2L V8
MOTORCRAFT​
ASH12263Strut
$ 397.79​
$ 0.00​
2​
$ 795.58​
MOTORCRAFT​
ASH24541Shock Absorber
$ 395.79​
$ 0.00​
2​
$ 791.58​
Shipping​
Ground
$ 46.98​
Tax​
$ 114.39​
Order Total
$ 1748.53
PayPal​
-$ 1748.53
Balance Due
$ 0.00
bubblehead93
Charleston
you can probably save $100 for the pair on the fronts... looks like a number of the dealer websale stores have the rears ranging from $330-400 each... not sure about availability in stock though...
also, you'll find the crew cab front strut Motorcraft p/n ASH12262 vice the ASH12263... not sure if there is an internal difference (valving, etc...)
TomDirt
Hesperia CA
The fronts (ASH12263) are available at $400 w/free shipping on eBay. So theres really no reason to rebuild the fronts on my 2011 other than they don't come with a Schrader Valve. Interesting
TomDirt
Hesperia CA
BL3Z-18124-J
ASH-12263
Rear
BL3Z-18125-K
ASH-24542
I think I just bought the last 2 rears (for the SCREW) on eBay. They're listed at $412 shipped. My old ones (pictured below) were probably original, with 148xxx miles. D-side still had pressure, P-side had no nitrogen and had spit oil on the shock shield. They also had baked white lithium grease on the tops.... I guess there was a squeaking issue (when the Pass shock stopped working) and the "fix" was spraying the tops
TomDirt
Hesperia CA
Lowest price I can find for oem rear Foxes as of today.
