When you get out of the truck with keys.. does your truck lock?
sniperm
sniperm
if you buy the elm and register on forscan and do the extended licance i can do it via team viewer. just a phone call and chat for 20-30 min lol. u turn off and on when asked and click ok.
quick program
autostart stop BCM 726-48-02 x0xx xxxx xxxx 1b
double honk delete BCM 726-41-02 xxx0 xxxx xxxx 2b
Secure Idle enable BCM 726-42-01 x1xx xxxx xxxx 3b
Panic Alarm BCM 726-37-01 xxxx xxx1 xxxx 4b
DRL - Parking Lights only (stock LEDs only) BCM 726-26-02 x1xx xxxx xxxx 5b
726-50-01 01xx 6b
autofold Mirrors - Lincoln Style (see desc in Notes) PDM 741-03-01 x84x xx 1p
PDM 741-12-01 Fxxx 2p
autofold Mirrors - Lincoln Style (see desc in Notes) DDM 740-03-01 x84x xx 1d
DDM 740-12-01 Fxxx 2d
quick boot with engine &trans temp IPC 720-07-01 xxxx xE5x 2xxx 1i with trailer brake
Fake engine noise disable ACM 727-01-01 xxxx x0xx xxxx 1acm
Stereo Extended Play APIM 7D0-01-01 xx*x xxxx xxxx 1apim Stereo Extended Play: A=off, 2=20mins, 3=30mins, 4=40mins, 5=50mins, 6=60mins (Sync 2 & Sync 3)
The forscan.. where do I buy this?
dlbb
so cal
sniperm
sniperm
forscan is free. lol u just buy the elm from the other post. team viewer is free too.
https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit a good place to start. follow the directions to download and get the extended licence.
https://docs.google.com/spreadsheet...iVSlDFGFHnfeuhb3RTMVz95730/edit#gid=815852466 this is where the codes come from. it will break some ppls brain. that is why i have my own sheet for what i did or is relevant to most raptor owners.
Ah..Thanks!!!
I will Look into this.. When I get everything ready..I'll contact you.
Thanks again!!!
GizmoVance
Hey, guys.. I just notice when I get out of my truck with my keys.. my truck makes a honk..but doesn't lock... I was about 20 foot away.. and my wife just opened the truck...
Wow. This thread went sideways quick and I don't think you ever got your question answered!
It is NORMAL (and very important) behavior for the car/truck to honk when walking away from a running vehicle with the FOB. Some vehicles politely chime, others are a little less "kind" and honk instead. ;-)
If you think about it, this makes complete sense just in case someone other than he driver accidentally walks away with the FOB in their purse/pocket!!
This is also a measure to prevent tossing the FOB into the trunk; causing it to lose the connection with the vehicle. Heck, some vehicles are so sensitive, they require the FOB to be in the front driver's area!
HTH
dlbb
so cal
nice. i got stuck on the 802a trim cause my wife requires leather. didn't even realize the push start was included. i just didn't want the sunroof or raptor trim every where.
